GL-iNet GL-B1300 site to site ovpn
I try to make a site to site openvpn connection on GL-iNet GL-B1300 fw 3.027 as client
the ovpn config runs on a raspbian pi. I try to use the same ovpn config file for the GL-B1300
on openwrt I can open the vpn connection but I can not send any paket through it:
any ideas, what can be wrong?
I guess it’s a problem in the firewall setting, but I don’t know
Setup
company network (192.168.30.0/24) - linux ovpn gateway - Internet - wlan openwrt as dhcp - lan openwrt - local network (10.49.222.0/24)
Maybe someone has a running configuration for it or can send me a link?
I try to import the ovpn file on the web interface. Then I can have only access from local to company network, but not the oposit direction.
Voip phone for example dosent work then.
config files:
[/etc/config/networks]
config interface ‘loopback’
option ifname ‘lo’
option proto ‘static’
option ipaddr ‘127.0.0.1’
option netmask ‘255.0.0.0’
config globals ‘globals’
option ula_prefix ‘fd52:0ba2:c80b::/48’
config interface ‘lan’
option force_link ‘1’
option type ‘bridge’
option netmask ‘255.255.255.0’
option ip6assign ‘60’
option hostname ‘GL-B1300-dc8-5G’
option ieee1905managed ‘1’
option ipaddr ‘10.49.222.1’
option ifname ‘eth1’
config interface ‘wan’
option proto ‘dhcp’
option ifname ‘eth0’
config interface ‘wan6’
option proto ‘dhcpv6’
config switch
option name ‘switch0’
option reset ‘1’
option enable_vlan ‘1’
config switch_vlan
option device ‘switch0’
option vlan ‘1’
option ports ‘0t 1 2 3 4’
config switch_vlan
option vlan ‘2’
option ports ‘0t 5’
config switch_ext
option name ‘QosPtMode’
option port_id ‘1’
option mode ‘dscp’
option status ‘enable’
config switch_ext
option port_id ‘2’
option mode ‘dscp’
config switch_ext
option port_id ‘3’
option mode ‘dscp’
config switch_ext
option port_id ‘4’
option mode ‘dscp’
config switch_ext
option port_id ‘5’
option mode ‘dscp’
config interface ‘guest’
option ifname ‘guest’
option ipaddr ‘192.168.9.1’
config interface ‘wwan’
option proto ‘dhcp’
option metric ‘20’
option ifname ‘wlan-sta0’
[/etc/config/firewall]
config defaults
option syn_flood ‘1’
option input ‘ACCEPT’
option output ‘ACCEPT’
option forward ‘REJECT’
option disabled ‘0’
config zone
option name ‘lan’
list network ‘lan’
option forward ‘ACCEPT’
option device ‘tun+’
config zone
option name ‘wan’
option input ‘REJECT’
option masq ‘1’
option mtu_fix ‘1’
option network ‘wan wan6 wwan’
config forwarding
option src ‘lan’
option dest ‘wan’
option enabled ‘1’
config rule
option name ‘Allow-DHCP-Renew’
option src ‘wan’
option proto ‘udp’
option dest_port ‘68’
option target ‘ACCEPT’
option family ‘ipv4’
config rule
option name ‘Allow-Ping’
option src ‘wan’
option proto ‘icmp’
option icmp_type ‘echo-request’
config rule
option name ‘Allow-IGMP’
option src ‘wan’
option proto ‘igmp’
config rule
option name ‘Allow-DHCPv6’
option src ‘wan’
option proto ‘udp’
option src_ip ‘fe80::/10’
option src_port ‘547’
option dest_ip ‘fe80::/10’
option dest_port ‘546’
option family ‘ipv6’
config rule
option name ‘Allow-MLD’
option src ‘wan’
option proto ‘icmp’
list icmp_type ‘130/0’
list icmp_type ‘131/0’
list icmp_type ‘132/0’
list icmp_type ‘143/0’
config rule
option name ‘Allow-ICMPv6-Input’
option src ‘wan’
option proto ‘icmp’
list icmp_type ‘echo-request’
list icmp_type ‘echo-reply’
list icmp_type ‘destination-unreachable’
list icmp_type ‘packet-too-big’
list icmp_type ‘time-exceeded’
list icmp_type ‘bad-header’
list icmp_type ‘unknown-header-type’
list icmp_type ‘router-solicitation’
list icmp_type ‘neighbour-solicitation’
list icmp_type ‘router-advertisement’
list icmp_type ‘neighbour-advertisement’
option limit ‘1000/sec’
config rule
option name ‘Allow-ICMPv6-Forward’
option src ‘wan’
option dest ‘*’
option proto ‘icmp’
config include
option path ‘/etc/firewall.user’
option reload ‘1’
config rule
option src ‘wan’
option dest ‘lan’
option proto ‘esp’
config rule
option src ‘wan’
option dest ‘lan’
option dest_port ‘500’
option proto ‘udp’
config rule ‘glservice_rule’
option name ‘glservice’
option dest_port ‘83’
option proto ‘tcp udp’
option src ‘wan’
option enabled ‘0’
config include ‘qcanssecm’
option type ‘script’
option path ‘/etc/firewall.d/qca-nss-ecm’
option family ‘any’
option reload ‘0’
config include ‘gls2s’
option path ‘/var/etc/gls2s.include’
option reload ‘1’
config include ‘glfw’
option path ‘/usr/bin/glfw.sh’
option reload ‘1’
config include ‘glqos’
option path ‘/usr/sbin/glqos.sh’
option reload ‘1’
config include ‘mwan3’
option path ‘/var/etc/mwan3.include’
option reload ‘1’
config zone ‘guestzone’
option name ‘guestzone’
option network ‘guest’
config forwarding ‘guestzone_fwd’
option src ‘guestzone’
option dest ‘wan’
option enabled ‘1’
config rule ‘guestzone_dhcp’
option name ‘guestzone_DHCP’
option proto ‘udp’
option dest_port ‘67-68’
config rule ‘guestzone_dns’
option name ‘guestzone_DNS’
option dest_port ‘53’
config forwarding ‘forwarding_wan’
option src ‘wan’
option dest ‘lan’
[openvpn config file client]
client
dev tun
proto udp
remote [remote-server] 5001
resolv-retry infinite
nobind
user nobody
group nogroup
persist-key
persist-tun
remote-cert-tls server
tls-auth ta.key 1
cipher AES-256-CBC
auth SHA256
verb 3
