GL.iNet GL-MT3000 FW 4.5.16 Backup of configuration?
I set up my GT-MT3000 yesterday and would like to make a backup of the configuration.
Unfortunately I can't find a menu item for this.
Can someone help me with how I can do this?
Thank you very much.
Patrick
You can make a backup inside Luci. You can access directly via the links I provided but also inside the glinet gui, you go to System > Advanced Settings
http://IP/cgi-bin/luci
Direct link:
http://IP/cgi-bin/luci/admin/system/flash
System > Backup / Flash Firmware
Many thanks.
Perfect.
Best regards,
Patrick
Thank you so much. Now i have a back up
I tried the direct link to backup but faced a login screen. What do I use to login? How do I overcome this??
Thanks,
John.
The password is the same for standard GL GUI.
