I see the gl.inet store has a barrel to female usb c connector but its always sold out. Does anyone use one that is similiar to the form factor they can recommend? Also if not that form factor, which ones do you use?
I bought this kit for Spitz AX. By luck the standard cable fit into the Sptiz AX, didn’t need another adapters:
Thanks. I will give it a try.
i got the one that is for starlink -
works with the spitz that i had and now the mudi7
Thanks. I will get this one as a backup too.
