GL.iNet GL-X3000 won't connect to T-Mobile Home Internet
My best guess is T-Mobile did something to break IPv4 routing on their CGNAT setup... and their native routers know how to handle that but the X3000 doesn't.
Hello, we are checking this issue.
Are also using the T-Mobile Home Internet service plan? Or are you on a different plan? Did you try different APN?
Yes, this is a T-Mobile Home Internet SIM. I've tried the fast.t-mobile.com and fbb.home APNs without success.
Yes, I've confirmed that IPV6 works perfectly fine while IPV4 doesn't after I disabled the "Interface Status Tracker" under "Multi-Lan". Did some research and it seems like Tmobiles is fully on IPV6 and using 464xlat to translate IPv4 packages to IPv6 at its Gateway (explains why my wireguard VPN on ipv4 is flaky recently). There is no issues with simcard or network registration as I confirmed with AT commands (e.g AT+CEER, AT+COPS?, etc)
I tried to install 464xlat package on the GL-XE3000, and I was able to ping ipv4 IP like 8.8.8.8, but noticed it was flaky where maybe 1/2 of the ping failed. Also I noticed that CPU showing at ~45% consistently with the 'top' command after the 464xlat package was installed (it seems to be saturating an entire CPU core (1/2 core on the device). CPU went back to normal after I uninstalled the package, so it looks to me like the device isn't powerful enough handle the IPv4 to IPv6 conversion. For those who are interested in trying the 464xlat package, I had to manually add a new 464xlat interface and make sure it is added to WAN firewall zone to have it working. The default 464xlat interface that get auto added after installation of the package shows not connected, and there's no way to modify the configuration.
Limitation of T-Mobile Home Internet - does not support prefix delegation, so i'm not sure how to get all my subnets to get its own IPV6 prefixes. Additionally, if your IOT devices don't support IPV6, you're out of luck. So my conclusion is if you're buying the GL-XE3000/X3000 to hopefully replace your T-Mobile Gateway and want to support dual stack IPv4 and IPv6 on your network, you're out of luck. The reason why I switched to the GL-XE3000 is so I can force 5G SA since the T-Mobile Gateway G4SE that I have currently only support 5G NSA, and at where I am living, the 4G signal is far worse than 5G, so my downstream is good but upstream is crap, so overall experience is crap especially for working from home.
I hope that helps.
TTL should be unset for TMHI, as far as I know. That setting is intended to mask “hotspot” usage (downstream router, devices, etc) as “phone” data usage to hide extra routing hops.
I realized that depending on what band your Gateway is connected to, it will determine if you have an ipv4 address or not. I noticed this when using the FX4100 business Gateway from T-Mobile. When it is connecting exclusively using 5G-NSA via b2 band for the upstream, it was getting a non 192.0.0.2 gateway IP. When I forced it to using 5G-SA only which connects to n41 band and the gateway ip returned back to 192.0.0.2. This probably what happened depending on where you are and whatever band the gateway decides to connect to.
With that said, after switching to the Inseego FX4100 router from T-Mobile (which allows you full configuration), there’s less of a need for my XE-3000. And it comes with WiFi 7 by default.
Any update on this? I am having the same issues.
Hi, we found that TMHI can work with GL router. Some of users cannot make it work, we suspect it's due to the ISP limitation. If you experience the connection issue with TMHI, please try:
  1. if router is updated to v4.8, go to cellular -> SIM Card Settings to change IP Type to IPv4&IPv6.
  2. run command AT+QCFG="clat". If it returns 0, enable it by AT+QCFG="clat",1 and then try again
So its seems I just ran into this issue last night with my router. Came home from work and everything was super slow/not working (been working for a month+ fine). Rebooted the router a few times, still same issue. Using fast.t-mobile as APN
Thought it was maybe the 4.8.4 software I was testing so I went back down to 4.8.3 release, same issue. Got fed up with the night and went to bed.
Woke up in the am
Factory reset the router a few times. Still nothing (what was weird is I had the gigsky APN set and got connection/internet). I was playing around with the config (came across your post) and now randomly fast.t-mobile.com is working again out of the blue
I dont remember what I had set on the 4.8.4 before I downgraded/factory reset it
Blah1234 did you ever get your issue sorted out?
