GL-inet & LuCi
Thank you in advance.
I have a MY1300 Beryl router with the latest software.
I have configured the gl-inet gui dashboard with IVPN wireguard protocol, enabled nextdns and the kill switch.
I have checked that wifi and LAN connections are going through wireguard and to nextdns.
I have not configured the firewall settings.
Am I good for a basic home setup?
Is LuCi just a more detailed method of configuration?
Do I need to config the LuCi firewall?
Again, thank you.
For MT1300 Luci may not be compatible in wireless config.
If your setup is working good I think you can leave it working like that.
