Model:GL-AR300M16-Ext
Wireless Router 300MBPs
I have a Samsung galaxy 24 ultra and the router will not pick up the hotspot. Any advice would be appreciated.
Check if you can lower the settings of the hotspot, so it will use 2.4 GHz and maybe WPA2 only.
So, i did that. I have my hotspot on and put in the numbers to set up my router. But it still not connecting. Is there a step I'm missing?
Does your travel router see the Wi-Fi?
no. I can't get to the screen to put the password in. the admin. When I plug my phone to the router, my phone doesn't get a notification or anything. Also. what's the button on the side besides the reset button?
Wait, wait, wait.
You are talking about Tethering, not about repeating the hotspot on your phone?
I guess you asked the 'Toggle button', it is a quick enable/disable button.
Do you use the Tethering or Repeater? There are 4 ways as WAN to work for the router. Please let me know your issue detail with some screenshot or syslog.
