I can connect the Mudi correctly via LAN or WLAN.
The address 192.168.8.1. is also displayed for the Mudi in Advanced IP Scanner. In both cases.
However, the Mudi is not available at http://192.168.8.1 . Also a ping to this address fails.
What can I do?
alzhao
January 24, 2020, 11:58am
#2
I replied you via email. Forum is better. Can you post more details as I asked in email?
I use a PC. A VPN is not enabled. A valid address 192.168.8.1 is displayed.
But this address is not responding. There is no ping possible and no access via the browser.
Now it works over WiFi. The central router had blocked the LAN address. Thank You
3G/4G Modem → SIM Card need PIN number.
How can I enter the PIN code?
3G/4G Modem:
I have inserted SIM card from telekom.de This is also recognized correctly.
The connection is displayed as “telekom.de ”.
SMS can be received.
Then comes the announcement: “No Internet” and in the admin panel:
„No Internet Connection“
All parameters are entered correctly.
alzhao
January 29, 2020, 3:51am
#8
You need to choose ttyUSB2 other than cdc-wdm0 in order to input pin code.
which LTE bands are supported? Also band 20 (800 GHz)?
which LTE bands are supported? Also band 20 (800 MHz)?
alzhao
January 29, 2020, 10:39am
#11
The Quectel LTE EP06 CAT6 module supports LTE Band 20, how do I know which module (CAT4 modules or CAT6 modules) is installed? Or are both modules always installed?
Now I see that CAT4 module also supports LTE Band 20. But CAT6 module is more powerful.
Does GL-E750C6 - Cat6 mean
solved: the device has a small sticker: EP06-E LA.
