GL.iNet Opal Wifi Trunk for Managed PoE swit h
I'm trying to figure out if there is a way to use VLANs and interface bridging to put my PoE security camera onto a dedicated vlan through a GL.iNet Opal wifi connection as a trunk connection. Basically, turning a PoE camera into a wifi PoE camera by sending the tagged packets through the managed PoE switch and opal to a Unifi gateway.
I know it works to use virtual network overide while the Opal is in extender mode. However, this doesn't allow the gateway to see anything behind the extender.
Thanks.
Can we have more details, how is the Opal connected to the internet?
Extender mode to Unifi AP that is controlled by Unifi gateway. Trying to make the wifi a trunk connection back to Unifi gateway.
