I'm not too familiar with how eSim works on a router. I did read through the GL-iNet eSim tutorial and that helped some. Wondering if anyone has had success getting a US Mobile plan installed on an eSim. Also, has anyone used US Mobile's "Network transfer" feature to switch to a different carrier?
I tried eSim (using the official GL-iNet eSim) with US Mobile and it did not work despite multiple attempts. The status screen would get to 90% and hang. I made sure I had the IMEI number set to the number that I provided US Mobile (that was the only number they requested). I then tried to install the eSim on my Pixel 7a and it installed successfully. The router I was using is the GL-X3000 Spitz AX running 4.7.4 firmware and the latest cellular module.
Hi @doczenith1 I have get your feedback and make connections in another post, we can deal with this in another post or email. I'll close this post, thank you for your information!
