now my Wifi is Working correctly i want to setup my Shadow to work with the T-Mobiele Web’n’Walk-Stick (yes its an old one, but i just want to use this in emergency to watch maybe some TV). If I install it to the USB-Port of the Shadow nothing happens and the stick is not regonized as Modem. I tried already to install it with “opkg update && opkg install wifitoggle” and tried if something is changed, but no change
uci show wifitoggle shows only the regular output and is no help
okay found in internet that there is a driver installable by yast. and i thought okay then look at opkg and then realized that at the glinet has only 44KiB free. Is that normal and how can i extend it. so i can try to intall something.
Edit:
Here is a pic that shows that there is nearly no space but still at temp space a lot. is it possible to use some MB from that space?
