I am new to all this. Trying to configure the Gl.iNet6416 and OpenVPN. Is there firmware with it already installed? If not then if I install the OpenVPN-ssl package do I configure it through command line or do I just get the GL-MT300A?
The 2.19 version here should contain VPN
http://www.gl-inet.com/firmware/6416/v1/
You can also install the luci-app-vpn (or similar name), but I use WinSCP and it’s build in command line editor to config. Still need to issue start\enable at command line or start through luci if installed. (I am on 2.13)
That worked! Thanks!
Super, Your welcome!
