Upon trying to establish a 3G connection with the GL-MiFi + Quectel UC20 daughter board I am stuck in the final PPP negotiation phase.
I have found I have to use /dev/ttyUSB3 for the data and not /dev/ttyUSB2 as with the ttyUSB2 port the dial script will give an ERROR at the ATDT command where the connect is being initiated. When I change to ttyUSB3 the connect script succeeds.
The CHAP authentication succeeds as well in the subsequent PPP negotiation phase, but after that I run into problems that I haven’t been able to solve with a couple of days of googling.
Here is my log:
Sat Jan 23 22:08:10 2016 daemon.notice netifd: Interface ‘wan’ is setting up now
Sat Jan 23 22:08:11 2016 daemon.notice netifd: Interface ‘wan’ is now down
Sat Jan 23 22:08:13 2016 kern.info kernel: [ 268.420000] usb 1-1.2: new high-speed USB device number 9 using ehci-platform
Sat Jan 23 22:08:13 2016 kern.info kernel: [ 268.540000] option 1-1.2:1.0: GSM modem (1-port) converter detected
Sat Jan 23 22:08:13 2016 kern.info kernel: [ 268.540000] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB0
Sat Jan 23 22:08:13 2016 kern.info kernel: [ 268.550000] option 1-1.2:1.1: GSM modem (1-port) converter detected
Sat Jan 23 22:08:13 2016 kern.info kernel: [ 268.570000] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB1
Sat Jan 23 22:08:13 2016 kern.info kernel: [ 268.570000] option 1-1.2:1.2: GSM modem (1-port) converter detected
Sat Jan 23 22:08:13 2016 kern.info kernel: [ 268.590000] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB2
Sat Jan 23 22:08:13 2016 kern.info kernel: [ 268.590000] option 1-1.2:1.3: GSM modem (1-port) converter detected
Sat Jan 23 22:08:13 2016 kern.info kernel: [ 268.610000] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB3
Sat Jan 23 22:08:13 2016 kern.info kernel: [ 268.610000] option 1-1.2:1.4: GSM modem (1-port) converter detected
Sat Jan 23 22:08:13 2016 kern.info kernel: [ 268.630000] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB4
Sat Jan 23 22:08:17 2016 daemon.notice netifd: Interface ‘wan’ is setting up now
Sat Jan 23 22:08:19 2016 kern.err kernel: [ 273.770000] option1 ttyUSB3: option_instat_callback: error -2
Sat Jan 23 22:08:19 2016 daemon.notice pppd[5358]: pppd 2.4.7 started by root, uid 0
Sat Jan 23 22:08:20 2016 local2.info chat[5360]: abort on (BUSY)
Sat Jan 23 22:08:20 2016 local2.info chat[5360]: abort on (NO CARRIER)
Sat Jan 23 22:08:20 2016 local2.info chat[5360]: abort on (ERROR)
Sat Jan 23 22:08:20 2016 local2.info chat[5360]: report (CONNECT)
Sat Jan 23 22:08:20 2016 local2.info chat[5360]: timeout set to 10 seconds
Sat Jan 23 22:08:20 2016 local2.info chat[5360]: send (AT&F^M)
Sat Jan 23 22:08:20 2016 local2.info chat[5360]: expect (OK)
Sat Jan 23 22:08:20 2016 local2.info chat[5360]: AT&F^M^M
Sat Jan 23 22:08:20 2016 local2.info chat[5360]: OK
Sat Jan 23 22:08:20 2016 local2.info chat[5360]: – got it
Sat Jan 23 22:08:20 2016 local2.info chat[5360]: send (ATE1^M)
Sat Jan 23 22:08:20 2016 local2.info chat[5360]: ^M
Sat Jan 23 22:08:20 2016 local2.info chat[5360]: ATE1^M^M
Sat Jan 23 22:08:20 2016 local2.info chat[5360]: send (AT+CGDCONT=1,“IP”,“portalmmm.nl”^M)
Sat Jan 23 22:08:20 2016 local2.info chat[5360]: timeout set to 30 seconds
Sat Jan 23 22:08:20 2016 local2.info chat[5360]: AT+CGDCONT=1,“IP”,“portalmmm.nl”^M^M
Sat Jan 23 22:08:20 2016 local2.info chat[5360]: send (ATD99**1#^M)
Sat Jan 23 22:08:20 2016 local2.info chat[5360]: expect (CONNECT)
Sat Jan 23 22:08:20 2016 local2.info chat[5360]: ATD99**1#^M^M
Sat Jan 23 22:08:20 2016 local2.info chat[5360]: CONNECT
Sat Jan 23 22:08:20 2016 local2.info chat[5360]: send ()
Sat Jan 23 22:08:20 2016 daemon.debug pppd[5358]: Script USE_APN=portalmmm.nl DIALNUMBER=99**1# /usr/sbin/chat -t5 -v -E -f /etc/chatscripts/3g.chat finished (pid 5359), status = 0x0
Sat Jan 23 22:08:20 2016 daemon.info pppd[5358]: Serial connection established.
Sat Jan 23 22:08:20 2016 daemon.debug pppd[5358]: using channel 3
Sat Jan 23 22:08:20 2016 daemon.info pppd[5358]: Using interface 3g-wan
Sat Jan 23 22:08:20 2016 daemon.notice pppd[5358]: Connect: 3g-wan <–> /dev/ttyUSB3
Sat Jan 23 22:08:21 2016 daemon.debug pppd[5358]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0x752a4fd9>]
Sat Jan 23 22:08:21 2016 daemon.debug pppd[5358]: rcvd [LCP ConfReq id=0x0 <asyncmap 0x0> <auth chap MD5> <magic 0x269f9c4> <pcomp> <accomp>]
Sat Jan 23 22:08:21 2016 daemon.debug pppd[5358]: sent [LCP ConfRej id=0x0 <pcomp> <accomp>]
Sat Jan 23 22:08:21 2016 daemon.debug pppd[5358]: rcvd [LCP ConfAck id=0x1 <asyncmap 0x0> <magic 0x752a4fd9>]
Sat Jan 23 22:08:21 2016 daemon.debug pppd[5358]: rcvd [LCP ConfReq id=0x1 <asyncmap 0x0> <auth chap MD5> <magic 0x269f9c4>]
Sat Jan 23 22:08:21 2016 daemon.debug pppd[5358]: sent [LCP ConfAck id=0x1 <asyncmap 0x0> <auth chap MD5> <magic 0x269f9c4>]
Sat Jan 23 22:08:21 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0x0 magic=0x752a4fd9]
Sat Jan 23 22:08:21 2016 daemon.debug pppd[5358]: rcvd [LCP DiscReq id=0x2 magic=0x269f9c4]
Sat Jan 23 22:08:21 2016 daemon.debug pppd[5358]: rcvd [CHAP Challenge id=0x1 <9aa12133ae9ff8e4f2cdbb7ede0bce5b>, name = “UMTS_CHAP_SRVR”]
Sat Jan 23 22:08:21 2016 daemon.debug pppd[5358]: sent [CHAP Response id=0x1 <59eea8ff1e6102dfeb551da56f831abb>, name = “""”]
Sat Jan 23 22:08:21 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0x0 magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:21 2016 daemon.debug pppd[5358]: rcvd [CHAP Success id=0x1 “”]
Sat Jan 23 22:08:21 2016 daemon.info pppd[5358]: CHAP authentication succeeded
Sat Jan 23 22:08:21 2016 daemon.notice pppd[5358]: CHAP authentication succeeded
Sat Jan 23 22:08:21 2016 daemon.debug pppd[5358]: sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
Sat Jan 23 22:08:22 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0x1 magic=0x752a4fd9]
Sat Jan 23 22:08:22 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0x1 magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:22 2016 daemon.debug pppd[5358]: rcvd [proto=0x0] 03 01 00 04
Sat Jan 23 22:08:22 2016 daemon.warn pppd[5358]: Unsupported protocol 0x0 received
Sat Jan 23 22:08:22 2016 daemon.debug pppd[5358]: sent [LCP ProtRej id=0x2 00 00 03 01 00 04]
Sat Jan 23 22:08:23 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0x2 magic=0x752a4fd9]
Sat Jan 23 22:08:23 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0x2 magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:24 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0x3 magic=0x752a4fd9]
Sat Jan 23 22:08:24 2016 daemon.debug pppd[5358]: sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
Sat Jan 23 22:08:24 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0x3 magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:25 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0x4 magic=0x752a4fd9]
Sat Jan 23 22:08:25 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0x4 magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:25 2016 daemon.debug pppd[5358]: rcvd [proto=0x0] 03 01 00 04
Sat Jan 23 22:08:25 2016 daemon.warn pppd[5358]: Unsupported protocol 0x0 received
Sat Jan 23 22:08:25 2016 daemon.debug pppd[5358]: sent [LCP ProtRej id=0x3 00 00 03 01 00 04]
Sat Jan 23 22:08:26 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0x5 magic=0x752a4fd9]
Sat Jan 23 22:08:26 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0x5 magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:27 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0x6 magic=0x752a4fd9]
Sat Jan 23 22:08:27 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0x6 magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:27 2016 daemon.debug pppd[5358]: sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
Sat Jan 23 22:08:28 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0x7 magic=0x752a4fd9]
Sat Jan 23 22:08:28 2016 daemon.debug pppd[5358]: rcvd [proto=0x0] 03 01 00 04
Sat Jan 23 22:08:28 2016 daemon.warn pppd[5358]: Unsupported protocol 0x0 received
Sat Jan 23 22:08:28 2016 daemon.debug pppd[5358]: sent [LCP ProtRej id=0x4 00 00 03 01 00 04]
Sat Jan 23 22:08:28 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0x7 magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:29 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0x8 magic=0x752a4fd9]
Sat Jan 23 22:08:29 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0x8 magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:30 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0x9 magic=0x752a4fd9]
Sat Jan 23 22:08:30 2016 daemon.debug pppd[5358]: sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
Sat Jan 23 22:08:30 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0x9 magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:31 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0xa magic=0x752a4fd9]
Sat Jan 23 22:08:31 2016 daemon.debug pppd[5358]: rcvd [proto=0x0] 03 01 00 04
Sat Jan 23 22:08:31 2016 daemon.warn pppd[5358]: Unsupported protocol 0x0 received
Sat Jan 23 22:08:31 2016 daemon.debug pppd[5358]: sent [LCP ProtRej id=0x5 00 00 03 01 00 04]
Sat Jan 23 22:08:31 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0xa magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:32 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0xb magic=0x752a4fd9]
Sat Jan 23 22:08:32 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0xb magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:33 2016 daemon.debug pppd[5358]: sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
Sat Jan 23 22:08:33 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0xc magic=0x752a4fd9]
Sat Jan 23 22:08:33 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0xc magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:34 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0xd magic=0x752a4fd9]
Sat Jan 23 22:08:34 2016 daemon.debug pppd[5358]: rcvd [proto=0x0] 03 01 00 04
Sat Jan 23 22:08:34 2016 daemon.warn pppd[5358]: Unsupported protocol 0x0 received
Sat Jan 23 22:08:34 2016 daemon.debug pppd[5358]: sent [LCP ProtRej id=0x6 00 00 03 01 00 04]
Sat Jan 23 22:08:34 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0xd magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:35 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0xe magic=0x752a4fd9]
Sat Jan 23 22:08:35 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0xe magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:36 2016 daemon.debug pppd[5358]: sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
Sat Jan 23 22:08:36 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0xf magic=0x752a4fd9]
Sat Jan 23 22:08:36 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0xf magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:37 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0x10 magic=0x752a4fd9]
Sat Jan 23 22:08:37 2016 daemon.debug pppd[5358]: rcvd [proto=0x0] 03 01 00 04
Sat Jan 23 22:08:37 2016 daemon.warn pppd[5358]: Unsupported protocol 0x0 received
Sat Jan 23 22:08:37 2016 daemon.debug pppd[5358]: sent [LCP ProtRej id=0x7 00 00 03 01 00 04]
Sat Jan 23 22:08:37 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0x10 magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:38 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0x11 magic=0x752a4fd9]
Sat Jan 23 22:08:38 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0x11 magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:39 2016 daemon.debug pppd[5358]: sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
Sat Jan 23 22:08:39 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0x12 magic=0x752a4fd9]
Sat Jan 23 22:08:39 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0x12 magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:40 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0x13 magic=0x752a4fd9]
Sat Jan 23 22:08:40 2016 daemon.debug pppd[5358]: rcvd [proto=0x0] 03 01 00 04
Sat Jan 23 22:08:40 2016 daemon.warn pppd[5358]: Unsupported protocol 0x0 received
Sat Jan 23 22:08:40 2016 daemon.debug pppd[5358]: sent [LCP ProtRej id=0x8 00 00 03 01 00 04]
Sat Jan 23 22:08:40 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0x13 magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:41 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0x14 magic=0x752a4fd9]
Sat Jan 23 22:08:41 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0x14 magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:42 2016 daemon.debug pppd[5358]: sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
Sat Jan 23 22:08:42 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0x15 magic=0x752a4fd9]
Sat Jan 23 22:08:42 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0x15 magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:43 2016 daemon.debug pppd[5358]: rcvd [proto=0x0] 03 01 00 04
Sat Jan 23 22:08:43 2016 daemon.warn pppd[5358]: Unsupported protocol 0x0 received
Sat Jan 23 22:08:43 2016 daemon.debug pppd[5358]: sent [LCP ProtRej id=0x9 00 00 03 01 00 04]
Sat Jan 23 22:08:43 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0x16 magic=0x752a4fd9]
Sat Jan 23 22:08:43 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0x16 magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:44 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0x17 magic=0x752a4fd9]
Sat Jan 23 22:08:44 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0x17 magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:45 2016 daemon.debug pppd[5358]: sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
Sat Jan 23 22:08:45 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0x18 magic=0x752a4fd9]
Sat Jan 23 22:08:45 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0x18 magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:46 2016 daemon.debug pppd[5358]: rcvd [proto=0x0] 03 01 00 04
Sat Jan 23 22:08:46 2016 daemon.warn pppd[5358]: Unsupported protocol 0x0 received
Sat Jan 23 22:08:46 2016 daemon.debug pppd[5358]: sent [LCP ProtRej id=0xa 00 00 03 01 00 04]
Sat Jan 23 22:08:46 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0x19 magic=0x752a4fd9]
Sat Jan 23 22:08:46 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0x19 magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:47 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0x1a magic=0x752a4fd9]
Sat Jan 23 22:08:47 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0x1a magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:48 2016 daemon.debug pppd[5358]: sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
Sat Jan 23 22:08:48 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0x1b magic=0x752a4fd9]
Sat Jan 23 22:08:48 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0x1b magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:49 2016 daemon.debug pppd[5358]: rcvd [proto=0x0] 03 01 00 04
Sat Jan 23 22:08:49 2016 daemon.warn pppd[5358]: Unsupported protocol 0x0 received
Sat Jan 23 22:08:49 2016 daemon.debug pppd[5358]: sent [LCP ProtRej id=0xb 00 00 03 01 00 04]
Sat Jan 23 22:08:49 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0x1c magic=0x752a4fd9]
Sat Jan 23 22:08:49 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0x1c magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:50 2016 daemon.debug pppd[5358]: sent [LCP EchoReq id=0x1d magic=0x752a4fd9]
Sat Jan 23 22:08:50 2016 daemon.debug pppd[5358]: rcvd [LCP EchoRep id=0x1d magic=0x269f9c4 75 2a 4f d9]
Sat Jan 23 22:08:51 2016 daemon.warn pppd[5358]: IPCP: timeout sending Config-Requests
Sat Jan 23 22:08:51 2016 daemon.debug pppd[5358]: sent [LCP TermReq id=0xc “No network protocols running”]
Sat Jan 23 22:08:51 2016 daemon.debug pppd[5358]: rcvd [LCP TermAck id=0xc]
Sat Jan 23 22:08:51 2016 daemon.notice pppd[5358]: Connection terminated.
Sat Jan 23 22:08:52 2016 kern.err kernel: [ 306.690000] option1 ttyUSB3: option_instat_callback: error -2
Sat Jan 23 22:08:52 2016 daemon.info pppd[5358]: Exit.
