I have bought the GL-MiFi EC25-E 4G device. Unfortunately only o2 SIM cards work the SIM cards from Vodafone the better ISP (Germany) do not work.
Can we fix the problem with a patch or other LTE module?
The Vodafone SIM cards work very well in another LTE router.
the first version ist 2… the new is 3. updatet yesterday.
In the menu there is no error message only a green dot at O2 if connected and a yellow dot at Vodafone if he tries to connect but this does not happen successfully.
I have also tried to get an LTE connection with different UMTS USB sticks, with O2 this was also successful with Vodafone but unfortunately not
I think there’s an APN config problem.
Because if I have the O2 SIM card in the router, I can set the APN like web.de or web.vodafone.de, which is the right APN for Vodafone and I get a connection to O2.
Via SSH the /etc/config/network options apn says ‘web.de’ this is a web address but no APN.
So I think that somewhere else the APN is set to ‘internet’ and therefore it works with O2
We judged APN Settings in the system through MCC and MNC of SIM card. If your SIM card is relatively new and not in the database, we may not be able to find the correct APN Settings
but I can’t get a connection to the internet / ISP
If it’s not the APN, what is the problem?
I bought the device for 135 Euro and can’t use it now that I’m angry.
Please let me have a look at your configuration. The configuration information is in ADMIN->3G/4G Modem->Manual Setup
If you can’t solve the problem, you can return the MIFI to us
