I’m working on a project using a GL-MiFi and Arduino GPS module (XC3712 with NEO6M2 receiver) in order to have GPS data be available for devices behind my MiFi.
I want to repurpose the serial console interface of the MiFi to accept NMEA strings from the GPS module.
I’ve attached the GPS module and using dmesg can see it advertised as /dev/ttyATH0.
Using minicom and setting my terminal settings I can see NMEA stings coming through (same as using cat /dev/ttyATH0).
Next I installed gpsd and gpsd-clients (for testing). The issue currently looks to be the ttyATH0 port is being consumed by another process which is preventing gpsd from connecting to the port. For instance if I’m running cgps I get no data received and eventually cgps times out, but in another shell I run minicom and some NMEA data gets delivered to gpsd when it first starts but then ceases after 1-2 seconds, then closing minicom there is another trickle of NMEA data to gpsd (verified by full 3D GPS lock in cgps) but then ceases after 1-2 seconds. This suggests to me something is grabbing the port once minicom hangs up its session.
I’ve referenced this link: OpenWrt Forum Archive and How to terminate console on serial port (UART) [Old OpenWrt Wiki] which gives details on disabling the console but haven’t had any luck getting gpsd to attach onto the serial console (ttyATH0) without using minicom to initiate and hang up which trickles through a little bit of NMEA data.
Some config outputs to try and disable any process from using the serial console:
cat /etc/inittab
::sysinit:/etc/init.d/rcS S boot
::shutdown:/etc/init.d/rcS K shutdown
#::askconsole:/bin/ash --login
cat /etc/sysctl.conf
#Defaults are configured in /etc/sysctl.d/* and can be customized in this file
kernel.printk = 0 4 1 7
Tried a couple of options in: /etc/rc.local (last few lines):
/usr/sbin/gpsd -G /dev/ttyATH0
stty -F /dev/ttyATH0 4:0:18b2:0:0:0:0:0:1:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0:0
both now commented out.
gpsd config:
gpsd.core=gpsd
gpsd.core.enabled=‘1’
gpsd.core.device=‘/dev/ttyATH0’
gpsd.core.port=‘2947’
gpsd.core.listen_globally=‘1’
Any thoughts?
