I have a GL-MiFi and am trying to use a Verizon SIM on the broadband side. It connects to Verizon and passes traffic. As soon as I connect a phone or device wirelessly to it it’ll reboot itself. I noticed if I stay wired with an ethernet connection it doesn’t reset, but the minute I pull the ethernet cable from the MiFi, connect to it wirelessly, and run a speedtest - bam! resets…
If i just wait a few minutes it’ll work again. Is there something that a wireless load from speedtest that would cause it to reset? I have tested with AT&T, Verizon and Visible and it does the same thing.
Also for reference - I have a great Verizon signal and I have tested both with running on the internal battery, as well as having it plugged in via USB in the wall with the same results.
I originally thought maybe a power hungry issue? But i have no idea at this point…
Wondering if maybe i’ve got a dud, or there’s something else underlying that i’m missing?
I am using auto config with this currently on a true Verizon Data card SIM.
Running: 3.105
Thanks!
