Alright - I spent some time working on it this evening and I still cannot get it to join up!
I followed all of these commands - I tried in both orders that have been posted in here and i still get sim unregistered and i never get the light to turn green and show Verizon. What am i doing wrong??
I am on Firmware version 3.105 - just looking for guidance please!
Oh you magnificent ba…rista?
My X750 on latest firmware has worked with my VZ hotspot SIM for months, then all of a sudden we needed to use it heavily during the outages in Texas this week. After one day suddenly “SIM card not registered”. It would work in the hotspot though. I even tried mimicking the IMEI of the hotspot.
Your solution worked for me but with vswinternet for APN.
In all honesty I didn’t use visible for long so I can’t say. Visible is getting smart and the only way I can think of is imei magic. I won’t get into detail here about it but outside of that… I say factory reset the mudi and try the steps again.
I’ve been having the same issue. For some reason I decided to just swap the Mudi SIM card with my phone (also Visible) and it worked. And the Mudi SIM worked in my phone. (Be warned, it’ll reset your voicemail at least on Android, so save any messages you don’t want lost.)
Then I switched them back it and it was all working again. I went through a lot of these steps many times and had no luck, so I’m not sure if doing that helped or not. But swapping the SIMs and then swapping them back just made it all work for me. I’m on the latest test firmware, but I don’t think that makes any difference now. I tried several others.
Edit: I was having dropout problems like mentioned earlier in this thread, so reverted back to 3.10 and it seems good again.
I got my X750 router working with my Visible SIM installed today. The trick was to REMOVE any Firewall/Custom rules with the TTL settings. Those TTL settings had been in there from prior testing.
Anyway, are there any other settings I could use to break the 5 MBPS download limit of Visible (that many have done using those TTL settings)?
I had a LTE router from LTEhacks and they changed their name again, but anyways using visible on that router is identical to using a GL.Inet router. When your doing the directions I noticed that using AT commands to reset modem will reset it. But your better off power cycling the router when you want to power off and back on during the AT commands. Also disconnect wires when you do a reset on AT commands and are going to start over. So this command chain:
AT+QPRTPARA=3 (modem to its OEM state)
AT+QMBNCFG=“AutoSel”,0 (stop Autoselect config on sim detection)
AT+QMBNCFG=“Deactivate” (disable MBN config)
AT+CFUN=1,1 (reboot the modem)
AT+QCFG=“usbnet”,2 ( MBIM protocol)
AT+QCFG=“nwscanmode”,3,1 ( 4G-LTE only)
AT+CGDCONT=1,“IPV6”,“VSBLINTERNET” (Has to be ipv6 only
See where it says AT+QMBNCFG="Deactivate"
I would just power cycle using the routers command page for doing that and not relying on AT+CFUN=1,1 to reboot the modem. So I think almost all routers will recommend this way. I also unplug the SIM card and put it back in at this point too then go on to use AT+QCFG="usbnet",2 and the following QCFG which are configuration parameters basically.
Also one last thing I noticed at times My service would want an APN of like VSBLINTERNET but other times it wanted the VERIZON APN name try both, and make sure your not adding the TTL lines double times because they were always added for me Everytime I would start the router with Visible sim on it. And I was messing up configs by adding the copy and paste stuff for the TTL
