Hi, is there any way I can access statistics about the battery in a GL-MiFi? I haven’t come across any docs for this so far, ideally it would be command-line via SSH etc.
Sorry that is not possible.
The battery is controlled by another MCU and it doesn’t talk with the router.
Ok, thank you for the quick response
If you’re technical enough it would fairly trivial to connect a fuel gauge like the MAX17043G+U on this breakout board from SparkFun ( SparkFun LiPo Fuel Gauge - TOL-10617 - SparkFun Electronics ) using I²C over the exposed GPIO ( I2C [Old OpenWrt Wiki] ) to get a reading, implement the low power state and so forth.
