i own a GL-MIFI and i have problems setting up a mobile broadband connection. In addition WIFi is unstable.
My “research” as follows:
No SD Card, no SIM: WIFI up and Device reachable
Factory Reset
Boot
Setup (LLanguage, Time, Password)
Shutdown (USB cable connected)
Inserted Sd Card
Boot
WIFI avilable
Inserted SIM Card
Boot
WIFI avilable
Setting up Connection
Internet Status
Modem Connection
Model: EC25
IMEI: XXXXXXXXX
Carrier : Detecting......
Please make sure the SIM card is inserted in correct direction and do a modem reset
SIM card is inserted with chip upwards and edge facing outside
Modem reset button clicked
Resetting.....
Noting on the GUI changes
Internet Status
New Connection
3G/4G
Region: Germany
Service Provider: T-Mobile(Germany)
Modem Device: /dev/ttyUSB2 (preselected)
Service Type: UMTS/GPRS (W-CDMA)
APN: internet.telekom
Dial Number: *99#
Pin: PIN of SIM card
Username: telekom
Password: tm
Clicked Submit
Internet Status
Modem: Connected - 2G full signal bars (HUAWEI MobileWIFI E5372 - Full 4G signal at the same location, with the same service provider)
Connecting to the internet - No IP obtained, no connection
Shutdown
Disconnected USB cable
Boot
waited approx 10 secs
Plugged USB Cable back in
WIFI shortly pops up, then dissapears
Shutdown
Removed SD Card
Boot
Shutdown
Removed SD Card
Boot
WIFI is up
No SD Card inserted
No SIm Inseted
No Internet Connection over 4G LTE (obvioulsy.... no SIM inserted)
I can start over at the factory reset, but nothing changes.
Firmware is: 2.271
So what am i doung wrong here?
Saw that there is a new FW v3.001-20180821
Flashed with “keep settings”
Is the APN thing addressed in this version? If so, i still have no option to set the APN.
After entering 3 chars the field is cleared. and “the circle keeps spinning”
No problem. As my mifi has no purpose atm because of these connection problems, I am thankful that you keep an eye on this.
Unfortunately 0823 didn’t change anything. I still cannot configure the APN and the circle next to the input field keeps spinning and resetting everything that I enter in that field.
It seems that the input field is buggy on MS Edge for Android. (Windows not tested yet).
I used Chrome and i could enter the APN.
After a modem reset i got a connection on /dev/ttyUSB3 but the connection speed is at 10% of my Huawei MIFI.
Am i using the wrond tty? Is there a way to boost the 4G signal? At the same spot the huawei mifi has 3/5 bars 4G and the GL-MIFi has 3/4 bars 3G. I’m using the hauwei mifi without external antennas.
You can try to force the setting to 4G only mode,Execute the command AT+QCFG=“nwscanmode”,3
Execute the command AT+QCFG=“nwscanmode”,0 revert to automatic mode
Thanks, that worked well. No my Huawei and may mifi are up on pat… in terms of delivered bandwidth. Is there a way to improve the signal strength for the mifi? My phone is about 5 times faster than the mifi and the Huawei.
