我尝试了几天后SSR与Trojan终于能运行了。因为空间不够装不下v2ray
参考资料:
https://aimuch.com/2019/10/12/GL-iNet-AR750-官方固件安装SSR-Plus-插件/
指令:
git clone GitHub - gl-inet/sdk: OpenWRT SDK for GL.iNet devices
sudo apt install … # 安装相关软件包
cd sdk
./download.sh ar71xx-1806
cd sdk/1806/ar71xx
echo ‘src-git kenzok8small GitHub - kenzok8/small: passwall基本依赖!’ >> feeds.conf.default
echo ‘src-git kenzok8packages GitHub - kenzok8/openwrt-packages: openwrt常用软件包’ >> feeds.conf.default
./scripts/feeds update -a
./scripts/feeds install -a
make menuconfig # 选中 Trojan
make package/feeds/luci/luci-base/compile V=99
make package/luci-app-ssr-plus/compile V=99
然后把相关ipk复制到路由器上并安装即可。
shadowsocks相关的ipk需要增加openwrt源或者从openwrt直接下载
https://archive.openwrt.org/releases/packages-18.06/mips_24kc/packages/shadowsocks-libev-ss-local_3.1.3-3_mips_24kc.ipk
https://archive.openwrt.org/releases/packages-18.06/mips_24kc/packages/shadowsocks-libev-ss-redir_3.1.3-3_mips_24kc.ipk
https://archive.openwrt.org/releases/packages-18.06/mips_24kc/packages/shadowsocks-libev-config_3.1.3-3_mips_24kc.ipk
注意如果要使用trojan务必安装编译出来的libopenssl,因为自带版本太旧。并且需要在路由器的SSH运行该指令 rm /overlay/upper/usr/lib/libcrypto.so.1.0.0 && rm /overlay/upper/usr/lib/libssl.so.1.0.0,不然依赖1.0.0版本的程序不能正常运行
如果要使用SSR 要关闭 重绑定保护
(我特别懒不想上传ipk文件)
感谢分享思路,最后一句扎心了,求ipk啊,,网盘也行
The GL Mifi ,could not to install protection tools,hope to upgrade to MV1000 that more useful for v2ray/trojan.
qq2439155747,or Xianyu :Freeroute
更新:
最后几句提到的指令大概是rm /overlay/upper/usr/lib/libcrypto.so.1.0.0 && ln -s /overlay/upper/usr/lib/libssl.so.1.1.0 /overlay/upper/usr/lib/libssl.so.1.0.0(我不太确定),并且在最新的固件版本中已不再需要
如果是空间足够的型号,要v2ray,要输入以下指令,因为自带的golang版本太旧无法完成编译
rm -fr feeds/packages/lang/golang
svn co https://github.com/openwrt/packages/trunk/lang/golang feeds/packages/lang/golang
另外建议先单独编译v2ray以确认其能成功编译:
make package/v2ray/compile V=99
如果看到要求安装wget-ssl,只要wget可以正常下载https协议的文件就不必从openwrt再下载。可以用opkg install --force-depends … 来忽略缺少的依赖
MIFI is slower, need X750
当初选择的时候,就发现内存和存储不够,我就选了mv1000w.
SmartDNS+Adblock+ SSR-Plus,is more useful.
