I understand that gl_monitor will make sure the WAN port is connected. I have a GLX750V2 and I keep getting this message in the log:
daemon.err gl_monitor[9794]: Error setting TIOCEXCL on /dev/ttyUSB2 - Not a tty(25).
I dont understand what does it actually mean, I have many X750 routers and none of them shows this message so I would like to find out it there is something wrong with this particular device.
Thank you
Can you share the contents of the following command?
ls /dev
Hi, here’s the output of the command
bus hwrng mtd1ro mtd5 mtdblock3 null sda1 ttyS12 ttyS5 ttyUSB2
cdc-wdm0 kmsg mtd2 mtd5ro mtdblock4 port shm ttyS13 ttyS6 ttyUSB3
console log mtd2ro mtd6 mtdblock5 ppp tty ttyS14 ttyS7 ubi_ctrl
cpu_dma_latency memory_bandwidth mtd3 mtd6ro mtdblock6 ptmx ttyS0 ttyS15 ttyS8 urandom
full mtd0 mtd3ro mtdblock0 net pts ttyS1 ttyS2 ttyS9 watchdog
fuse mtd0ro mtd4 mtdblock1 network_latency random ttyS10 ttyS3 ttyUSB0 zero
gpiochip0 mtd1 mtd4ro mtdblock2 network_throughput sda ttyS11 ttyS4 ttyUSB1
Quoute does not show it but I actually I noticed /dev/ttyUSB2 is different from other USB ports
So this I also check its permissions, these are from the affected x750
crw-rw---- 1 root dialout 188, 0 Feb 19 16:41 /dev/ttyUSB0
crw-rw---- 1 root dialout 188, 1 Feb 19 16:41 /dev/ttyUSB1
-rw-r--r-- 1 root dialout 2468 Mar 1 10:16 /dev/ttyUSB2
crw-rw---- 1 root dialout 188, 3 Feb 19 16:41 /dev/ttyUSB3
And these are from an x750 working properly
crw-rw---- 1 root dialout 188, 0 Mar 1 08:22 /dev/ttyUSB0
crw-rw---- 1 root dialout 188, 1 Feb 7 11:15 /dev/ttyUSB1
crw-rw---- 1 root dialout 188, 2 Feb 7 11:15 /dev/ttyUSB2
crw-rw---- 1 root dialout 188, 3 Mar 1 11:00 /dev/ttyUSB3
crw-rw---- 1 root dialout 188, 4 Feb 7 11:15 /dev/ttyUSB4
It looks like ttyUSB2 is just a normal file, not a device file, you can try to delete it and restart the device.
