I’m getting this error message up to 3 times per day on slate. it’s not a ‘huge’ issue but every time it does a restart of the switch I get a new ip address on the wan which is a bit of a pain (ISP issue but not really necessary).
Current Version3.100
Compile Time2019-12-21 10:01:57
Feb 6 13:44:30 GL-AR750S gl_monitor[3355]: Failed to connect to the switch. Use the “list” command to see which switches are available.
Feb 9 21:41:59 GL-AR750S gl_monitor[3355]: Failed to connect to the switch. Use the “list” command to see which switches are available.
Feb 10 04:33:40 GL-AR750S gl_monitor[3355]: Failed to connect to the switch. Use the “list” command to see which switches are available.
Feb 10 05:03:48 GL-AR750S gl_monitor[3355]: Failed to connect to the switch. Use the “list” command to see which switches are available.
Feb 10 07:28:37 GL-AR750S gl_monitor[3355]: Failed to connect to the switch. Use the “list” command to see which switches are available.
Feb 11 06:51:46 GL-AR750S gl_monitor[3355]: Failed to connect to the switch. Use the “list” command to see which switches are available.
Feb 12 16:52:50 GL-AR750S gl_monitor[3355]: Failed to connect to the switch. Use the “list” command to see which switches are available.
Feb 13 04:16:28 GL-AR750S gl_monitor[3355]: Failed to connect to the switch. Use the “list” command to see which switches are available.
Feb 14 08:29:40 GL-AR750S gl_monitor[3355]: Failed to connect to the switch. Use the “list” command to see which switches are available.
Feb 14 23:09:38 GL-AR750S gl_monitor[3355]: Failed to connect to the switch. Use the “list” command to see which switches are available.
Feb 15 11:19:35 GL-AR750S gl_monitor[3355]: Failed to connect to the switch. Use the “list” command to see which switches are available.
