GL-MT 3000 - LAN Port not working
Hello!
I use the router GL-MT3000, Firmware 4.5.16. I do have an issue with the LAN Port ETH1 which is not function.
The WAN port ETH0 is assigned an uplink to the WAN router and a WAN IP address 192.168.2. 209.
However, I haven’t been able to connect to a notebook via LAN cable for some time now. The interface on the notebook does not get a connection. The connection remains “off”. Of course I tested this with another PC or different cable without success, the interface stays “off”.
Even the router did not recognise the connection to the notebook, the interface stays off.
I’ve already reset the router to factory settings. Even without success.
I ask for your help.
Your Jo
SSH:
logread -e link:
Sat Mar 30 05:26:53 2024 kern.notice kernel: [   35.974703] 7981@C01L3,wifi_sys_linkdown() 1363: wdev idx = 2
Sat Mar 30 05:26:53 2024 kern.notice kernel: [   35.980959] 7981@C08L3,hw_ctrl_flow_v2_link_down() 123: wdev_idx=2
Sat Mar 30 05:26:54 2024 kern.notice kernel: [   36.165236] 7981@C01L3,wifi_sys_linkup() 1231: wdev idx = 2
Sat Mar 30 05:26:54 2024 kern.notice kernel: [   36.257975] 7981@C08L3,hw_ctrl_flow_v2_link_up() 72: wdev_idx=2
Sat Mar 30 05:26:54 2024 kern.warn kernel: [   36.496547] WiFi@C08L2,ap_link_down() 7161: (caller:wdev_do_linkdown+0x20/0x38 [mt_wifi]), wdev(1)
Sat Mar 30 05:26:54 2024 kern.err kernel: [   36.505813] 7981@C08L1,UpdateBeaconHandler() 1891: wdev(1) bss not ready (state:2, caller:ap_link_down+0x84/0x130 [mt_wifi])!!
Sat Mar 30 05:26:54 2024 kern.notice kernel: [   36.517231] 7981@C01L3,wifi_sys_linkdown() 1363: wdev idx = 1
Sat Mar 30 05:26:54 2024 kern.notice kernel: [   36.524094] 7981@C08L3,hw_ctrl_flow_v2_link_down() 123: wdev_idx=1
Sat Mar 30 05:26:54 2024 kern.warn kernel: [   36.638479] WiFi@C08L2,ap_link_down() 7161: (caller:wdev_do_linkdown+0x20/0x38 [mt_wifi]), wdev(3)
Sat Mar 30 05:26:54 2024 kern.err kernel: [   36.647881] 7981@C08L1,UpdateBeaconHandler() 1891: wdev(3) bss not ready (state:2, caller:ap_link_down+0x84/0x130 [mt_wifi])!!
Sat Mar 30 05:26:54 2024 kern.notice kernel: [   36.659390] 7981@C01L3,wifi_sys_linkdown() 1363: wdev idx = 3
Sat Mar 30 05:26:54 2024 kern.notice kernel: [   36.666292] 7981@C08L3,hw_ctrl_flow_v2_link_down() 123: wdev_idx=3
Sat Mar 30 05:26:59 2024 daemon.notice netifd: Network device 'ra0' link is up
Sat Mar 30 05:26:59 2024 daemon.notice netifd: Network device 'rax0' link is up
Sat Mar 30 05:27:01 2024 daemon.notice procd: /etc/rc.d/S80tailscale: 2024/03/30 04:27:01 cleanup: list tables: netlink receive: invalid argument
Sat Mar 30 05:29:42 2024 kern.info kernel: [  204.032966] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/2500base-x link mode
Sat Mar 30 05:29:42 2024 kern.info kernel: [  204.049915] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
logread -e netifd
Sat Mar 30 05:26:54 2024 daemon.notice netifd: Wireless device 'mt798111' is now up
Sat Mar 30 05:26:59 2024 daemon.notice netifd: Wireless device 'mt798112' is now up
Sat Mar 30 05:29:41 2024 daemon.notice netifd: wan (4074): udhcpc: received SIGTERM
Sat Mar 30 05:29:41 2024 daemon.notice netifd: wan (4074): udhcpc: unicasting a release of 192.168.2.209 to 192.168.2.1
Sat Mar 30 05:29:41 2024 daemon.notice netifd: wan (4074): udhcpc: sending release
Sat Mar 30 05:29:41 2024 daemon.notice netifd: wan (4074): udhcpc: entering released state
Sat Mar 30 05:29:41 2024 daemon.notice netifd: wan (4074): Command failed: Permission denied
Sat Mar 30 05:29:41 2024 daemon.notice netifd: Interface 'wan' is now down
Sat Mar 30 05:29:41 2024 daemon.notice netifd: Interface 'wan' is disabled
Sat Mar 30 05:29:42 2024 daemon.notice netifd: Interface 'wan' is enabled
Sat Mar 30 05:29:42 2024 daemon.notice netifd: Interface 'wan' is setting up now
Sat Mar 30 05:29:42 2024 daemon.notice netifd: wan (9411): udhcpc: started, v1.33.2
Sat Mar 30 05:29:42 2024 daemon.notice netifd: wan (9411): udhcpc: sending discover
Sat Mar 30 05:29:44 2024 daemon.notice netifd: wan (9411): udhcpc: sending select for 192.168.2.209
Sat Mar 30 05:29:44 2024 daemon.notice netifd: wan (9411): udhcpc: lease of 192.168.2.209 obtained, lease time 691200
Sat Mar 30 05:29:44 2024 daemon.notice netifd: Interface 'wan' is now up
ifconfig
br-lan    Link encap:Ethernet  HWaddr 94:83:C4:27:81:AF
          inet addr:192.168.8.1  Bcast:192.168.8.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:9473 errors:0 dropped:0 overruns:0 frame:0
          TX packets:21677 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:3534021 (3.3 MiB)  TX bytes:13734217 (13.0 MiB)
eth0      Link encap:Ethernet  HWaddr 94:83:C4:27:81:AE
          inet addr:192.168.2.209  Bcast:192.168.2.255  Mask:255.255.255.0
          inet6 addr: fe80::9683:c4ff:fe27:81ae/64 Scope:Link
          RX packets:31502 errors:0 dropped:0 overruns:0 frame:0
          TX packets:23458 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:13980518 (13.3 MiB)  TX bytes:5383939 (5.1 MiB)
          Interrupt:75
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:189 errors:0 dropped:0 overruns:0 frame:0
          TX packets:189 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:18706 (18.2 KiB)  TX bytes:18706 (18.2 KiB)
ra0       Link encap:Ethernet  HWaddr 94:83:C4:27:81:B0
          RX packets:24085 errors:2570 dropped:0 overruns:0 frame:0
          TX packets:65114 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:7406575 (7.0 MiB)  TX bytes:41219604 (39.3 MiB)
          Interrupt:7
rax0      Link encap:Ethernet  HWaddr 94:83:C4:27:81:B1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
ethtool eth0
Settings for eth0:
        Supported ports: [ MII ]
        Supported link modes:   2500baseT/Full
        Supported pause frame use: Symmetric Receive-only
        Supports auto-negotiation: No
        Supported FEC modes: Not reported
        Advertised link modes:  2500baseT/Full
        Advertised pause frame use: Symmetric Receive-only
        Advertised auto-negotiation: No
        Advertised FEC modes: Not reported
        Speed: 1000Mb/s
        Duplex: Full
        Port: MII
        PHYAD: 0
        Transceiver: internal
        Auto-negotiation: on
        Current message level: 0x000000ff (255)
                               drv probe link timer ifdown ifup rx_err tx_err
        Link detected: yes
 ethtool eth1
Settings for eth1:
        Supported ports: [ TP AUI BNC MII FIBRE Backplane ]
        Supported link modes:   10baseT/Half 10baseT/Full
                                100baseT/Half 100baseT/Full
                                1000baseT/Half 1000baseT/Full
                                1000baseX/Full
        Supports auto-negotiation: Yes
        Advertised link modes:  Not reported
        Advertised pause frame use: No
        Speed: Unknown!
        Duplex: Half
        Port: MII
        PHYAD: 0
        Auto-negotiation: off
        Link detected: no
I have done an other check.
I connected the LAN ETH1 Interface of the Router with a small, unmanaged Desktop Switch Netgear GS105. The concerning Switchport stays down, the LEDs are off. Using an different LAN cable as above.
Crosscheck with the LAN Port of the Notebook, the Switch Port is going up, the LEDs are on. Using the same LAN cable. Even Windows recognized the LAN Port is up.
Yours Jo
any update with the above issue? Because im having the same issue. Lan port eth1 would not connect to anything. Just want to note I have reset everything back to factory default to make sure is not firewall or NAT forwarding released.
Check log it say the following.
mtk_soc_eth 15100000.ethernet.eth1: Link is UP - 1Gbps/Full - flow control rx/tx
br-lan: port1(eth1) entered blocking state
br-lan: port1(eth1) entered forwarding state
update: eth1(UP)->apclix0(UP), active path3:
May I know if the question has resolved now?
Please contact [email protected] to let us provide the customer service for you if you still have.
Could you please share more detail syslog with us, including the LAN from disconnect to connect the Ethernet cable. As according to your mentioned logs, seems the LAN/Eth1 port hardware is ok, please check if can the lower device DHCP process, such as discover/offer/request/ACK?
This look suspicious to me :thinking:, this is the psysical port lan we speak off not some sort of usb ethernet adapter?
normally you won't expect a ethernet port to be half duplex, when i think about half duplex my thoughts are pointing to wireless.
I would like to see the following configurations /etc/config/network and /etc/config/wireless and /etc/config/firewall would be nice to see if something isn't right here.
And if possible also show logs :+1:
^ also it is possible your ethernet cable is not good, on my mt6000 it reports under port: twisted pair, not MII, maybe it is a cross cable?
Any solution to this? I have a old AC1300 and have been utilizing the LAN ports and both moved into the blocking state overnight. This was about 6 months ago. Both connected to windows OS desktops. Wireless side of the router works fine.
