I haven’t try to connect my whole house but I figure I shouldn’t have any issues the beryl can hold more than I need. I ll do the test to connect a couple of devices to see what happen, so far is working great, I dont regret having the beryl with easytether
I’m having issues with 10+ low bandwidth devices. Just curious if you have similar probs. I’m trying to figure out if it’s easytether bottleneck or the AR150 I have and I’ll get a better model.
I’ve got the beryl. Setup was very easy, but works no better than the AR150.
I wish I knew how to troubleshoot.
I’ve got 2 wired devices: a camera hub station that does not actively use bandwidth (only on motion), and a door lock module that doesn’t use much bandwidth.
On 2G I have 7 low bandwidth devices: led lights mostly.
On 5G I have 3 devices: two desktop computers and a laptop.
When trying to use the desktop computers the network completely fails, and I have to restart everything. I’ll open a game, like fortnite and it takes 5-15 minutes to start, and when it does the connection is SOLID for hours.
So something is happening. The setup works, but it’s fickle and I’m not sure what sets it off.
Seems that it is easytether driver limitation
You’re probably right. I will test with native tethering. Wish there was another way to use native without blowing through data so fast. Paying 400$ for three cell phones you should get unlimited tethering
My apologies I still haven’t try my whole house I haven’t had the time I usually use it when I’m not at home. But still mine is working great. Yes at the beginning I had to factory reset everything until I got it to work. Once I got it I did a final factory reset and did a clean set up. And so far no issues at all. Have you try a factory reset and a new clean set up?
Fernando- no worries, but yes I am very interested in hearing your experience. I am not sure what is happening. When I use easytether when all of my devices are connected, and I go on a desktop to launch a game (fortnite), or open a web browser and search, everything just keeps loading until I am met with the error: This site can’t be reached ERR_CONNECTION_TIMED_OUT- after a few minutes it refreshed the page about half way, and then it happens again. As far as fortnite, the game just is stuck on the server connection screen, just keeps loading. If I leave it for about 15 minutes it eventually connects, THEN I can play completely uninterrupted and at great speed for however long I need. It’s really weird. During this time, I may see my camera hub attached the the network disconnect, but with whatever is getting direct bandwidth I am solid. Not sure where to look for logs to show this. I will say, there was improvement when I used native tethering instead of ET, but obviously that defeats what I am trying to do here.
Another example- playing fortnite, everything great.
Turn on second desktop computer- load fortnite… kicks us both off.
In LUCI I dont see any errors or maybe I dont know how to read it.
Diagnostics:
IPv4 Traceroute:
Error XHR request timed out
IPv4 Ping:
PING openwrt.org (139.59.209.225): 56 data bytes
— openwrt.org ping statistics —
5 packets transmitted, 0 packets received, 100% packet loss
in kernel log (lots of lines of this):
[234635.071230] AP SETKEYS DONE - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=11 from 34:E8:94:BC:91:8E
[234635.071230]
[234704.803256] WextMboSendStaDisassocToDaemonEvent [64:52:99:ec:05:55] sizeof 6 report_buf_len 6 buflen 180 msg_type MBO_MSG_REMOVE_STA
[234825.797279] WextMboSendStaDisassocToDaemonEvent [64:52:99:ec:05:55] sizeof 6 report_buf_len 6 buflen 180 msg_type MBO_MSG_REMOVE_STA
[234946.791921] WextMboSendStaDisassocToDaemonEvent [64:52:99:ec:05:55] sizeof 6 report_buf_len 6 buflen 180 msg_type MBO_MSG_REMOVE_STA
[235067.787303] WextMboSendStaDisassocToDaemonEvent [64:52:99:ec:05:55] sizeof 6 report_buf_len 6 buflen 180 msg_type MBO_MSG_REMOVE_STA
[235188.780129] WextMboSendStaDisassocToDaemonEvent [64:52:99:ec:05:55] sizeof 6 report_buf_len 6 buflen 180 msg_type MBO_MSG_REMOVE_STA
[235276.345998] ASSOC - 1 receive DIS-ASSOC request
[235276.352461] WextMboSendStaDisassocToDaemonEvent [34:e8:94:bc:91:8e] sizeof 6 report_buf_len 6 buflen 180 msg_type MBO_MSG_REMOVE_STA
[235276.364979] ASSOC - 1 receive DIS-ASSOC request
[235276.369582] ASSOC - 1 receive DIS-ASSOC request
[235276.374177] ASSOC - 1 receive DIS-ASSOC request
[235276.378787] ASSOC - 1 receive DIS-ASSOC request
[235277.622415] AP SETKEYS DONE - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=11 from 34:E8:94:BC:91:8E
[235277.622415]
[235281.686564] 9ff, flush one!
[235309.773666] WextMboSendStaDisassocToDaemonEvent [64:52:99:ec:05:55] sizeof 6 report_buf_len 6 buflen 180 msg_type MBO_MSG_REMOVE_STA
[235431.867712] WextMboSendStaDisassocToDaemonEvent [64:52:99:ec:05:55] sizeof 6 report_buf_len 6 buflen 180 msg_type MBO_MSG_REMOVE_STA
[235552.862335] WextMboSendStaDisassocToDaemonEvent [64:52:99:ec:05:55] sizeof 6 report_buf_len 6 buflen 180 msg_type MBO_MSG_REMOVE_STA
[235673.855907] WextMboSendStaDisassocToDaemonEvent [64:52:99:ec:05:55] sizeof 6 report_buf_len 6 buflen 180 msg_type MBO_MSG_REMOVE_STA
[235794.850168] WextMboSendStaDisassocToDaemonEvent [64:52:99:ec:05:55] sizeof 6 report_buf_len 6 buflen 180 msg_type MBO_MSG_REMOVE_STA
[235915.844627] WextMboSendStaDisassocToDaemonEvent [64:52:99:ec:05:55] sizeof 6 report_buf_len 6 buflen 180 msg_type MBO_MSG_REMOVE_STA
In System log:
Tue Apr 20 16:11:59 2021 daemon.warn easytether-usb[23123]: acquired interface tap-easytether
Tue Apr 20 16:11:59 2021 daemon.notice netifd: Interface ‘wan’ is enabled
Tue Apr 20 16:11:59 2021 daemon.warn easytether-usb[23123]: dropped root privileges
Tue Apr 20 16:11:59 2021 daemon.notice netifd: Network device ‘tap-easytether’ link is up
Tue Apr 20 16:11:59 2021 daemon.notice netifd: Interface ‘wan’ has link connectivity
Tue Apr 20 16:11:59 2021 daemon.notice netifd: Interface ‘wan’ is setting up now
Tue Apr 20 16:11:59 2021 daemon.warn easytether-usb[23123]: now CONNECTING
Tue Apr 20 16:11:59 2021 daemon.notice netifd: wan (23152): udhcpc: started, v1.30.1
Tue Apr 20 16:11:59 2021 daemon.warn easytether-usb[23123]: now CONNECTED
Tue Apr 20 16:11:59 2021 daemon.notice netifd: wan (23152): udhcpc: sending discover
Tue Apr 20 16:11:59 2021 daemon.notice netifd: wan (23152): udhcpc: sending select for 192.168.117.2
Tue Apr 20 16:11:59 2021 daemon.notice netifd: wan (23152): udhcpc: lease of 192.168.117.2 obtained, lease time 4294967295
Tue Apr 20 16:11:59 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 34:20:03:51:60:ed
Tue Apr 20 16:11:59 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.206 34:20:03:51:60:ed
Tue Apr 20 16:11:59 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.206 34:20:03:51:60:ed
Tue Apr 20 16:11:59 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.206 34:20:03:51:60:ed
Tue Apr 20 16:11:59 2021 daemon.notice netifd: Interface ‘wan’ is now up
Tue Apr 20 16:11:59 2021 daemon.info dnsmasq[3472]: reading /tmp/resolv.conf.auto
Tue Apr 20 16:11:59 2021 daemon.info dnsmasq[3472]: using local addresses only for domain test
Tue Apr 20 16:11:59 2021 daemon.info dnsmasq[3472]: using local addresses only for domain onion
Tue Apr 20 16:11:59 2021 daemon.info dnsmasq[3472]: using local addresses only for domain localhost
Tue Apr 20 16:11:59 2021 daemon.info dnsmasq[3472]: using local addresses only for domain invalid
Tue Apr 20 16:11:59 2021 daemon.info dnsmasq[3472]: using local addresses only for domain bind
Tue Apr 20 16:11:59 2021 daemon.info dnsmasq[3472]: using local addresses only for domain lan
Tue Apr 20 16:11:59 2021 daemon.info dnsmasq[3472]: using nameserver 192.168.117.1#53
Tue Apr 20 16:12:02 2021 user.info mwan3rtmon[2541]: Detect rtchange event.
Tue Apr 20 16:12:03 2021 user.notice firewall: Reloading firewall due to ifup of wan (tap-easytether)
Tue Apr 20 16:12:21 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.181 98:48:27:b0:46:54
Tue Apr 20 16:12:21 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.181 98:48:27:b0:46:54 DESKTOP-96L49GF
Tue Apr 20 16:16:37 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 7c:72:e4:02:0a:e2
Tue Apr 20 16:16:37 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.216 7c:72:e4:02:0a:e2
Tue Apr 20 16:16:37 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.216 7c:72:e4:02:0a:e2
Tue Apr 20 16:16:37 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.216 7c:72:e4:02:0a:e2
Tue Apr 20 17:14:22 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 34:20:03:59:99:5a
Tue Apr 20 17:14:22 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.241 34:20:03:59:99:5a
Tue Apr 20 17:14:22 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.241 34:20:03:59:99:5a
Tue Apr 20 17:14:22 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.241 34:20:03:59:99:5a
Tue Apr 20 17:15:53 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) a8:bb:50:86:7d:3b
Tue Apr 20 17:15:53 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.137 a8:bb:50:86:7d:3b
Tue Apr 20 17:15:57 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) a8:bb:50:82:54:6e
Tue Apr 20 17:15:57 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.159 a8:bb:50:82:54:6e
Tue Apr 20 17:15:57 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) a8:bb:50:86:7d:3b
Tue Apr 20 17:15:57 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.137 a8:bb:50:86:7d:3b
Tue Apr 20 17:15:57 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.137 a8:bb:50:86:7d:3b
Tue Apr 20 17:15:57 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.137 a8:bb:50:86:7d:3b wiz_867d3b
Tue Apr 20 17:15:57 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.159 a8:bb:50:82:54:6e
Tue Apr 20 17:15:57 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.159 a8:bb:50:82:54:6e wiz_82546e
Tue Apr 20 18:47:19 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.232 f0:18:98:3b:10:71
Tue Apr 20 18:47:19 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.232 f0:18:98:3b:10:71 Allissas-MBP
Tue Apr 20 20:14:03 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.181 98:48:27:b0:46:54
Tue Apr 20 20:14:03 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.181 98:48:27:b0:46:54 DESKTOP-96L49GF
Tue Apr 20 20:35:46 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.181 98:48:27:b0:46:54
Tue Apr 20 20:35:46 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.181 98:48:27:b0:46:54 DESKTOP-96L49GF
Tue Apr 20 20:43:59 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 34:20:03:52:0c:bc
Tue Apr 20 20:43:59 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.195 34:20:03:52:0c:bc
Tue Apr 20 20:43:59 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.195 34:20:03:52:0c:bc
Tue Apr 20 20:43:59 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.195 34:20:03:52:0c:bc
Tue Apr 20 21:28:16 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 7c:72:e4:02:0a:e2
Tue Apr 20 21:28:16 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.216 7c:72:e4:02:0a:e2
Tue Apr 20 21:28:16 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.216 7c:72:e4:02:0a:e2
Tue Apr 20 21:28:16 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.216 7c:72:e4:02:0a:e2
Tue Apr 20 21:28:43 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.130 44:61:32:a1:67:17
Tue Apr 20 21:28:43 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.130 44:61:32:a1:67:17 Canteloupe-Lemonade
Tue Apr 20 21:49:34 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) d6:90:d6:11:eb:84
Tue Apr 20 21:49:34 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.148 d6:90:d6:11:eb:84
Tue Apr 20 21:49:35 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.148 d6:90:d6:11:eb:84
Tue Apr 20 21:49:35 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.148 d6:90:d6:11:eb:84 L337
Tue Apr 20 21:50:00 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 34:20:03:52:0c:bc
Tue Apr 20 21:50:00 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.195 34:20:03:52:0c:bc
Tue Apr 20 21:50:00 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.195 34:20:03:52:0c:bc
Tue Apr 20 21:50:00 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.195 34:20:03:52:0c:bc
Tue Apr 20 21:51:56 2021 daemon.info dnsmasq-dhcp[3472]: DHCPRELEASE(br-lan) 192.168.8.148 d6:90:d6:11:eb:84
Tue Apr 20 21:59:26 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.206 34:20:03:51:60:ed
Tue Apr 20 21:59:26 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.206 34:20:03:51:60:ed
Tue Apr 20 21:59:37 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.205 34:20:03:51:66:f3
Tue Apr 20 21:59:37 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.205 34:20:03:51:66:f3
Tue Apr 20 22:11:09 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.143 a4:11:62:77:02:cf
Tue Apr 20 22:11:09 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.143 a4:11:62:77:02:cf VMB4500
Tue Apr 20 22:46:38 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.181 98:48:27:b0:46:54
Tue Apr 20 22:46:38 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.181 98:48:27:b0:46:54 DESKTOP-96L49GF
Tue Apr 20 22:46:54 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 192.168.8.121 34:e8:94:bc:91:8e
Tue Apr 20 22:46:54 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.121 34:e8:94:bc:91:8e
Tue Apr 20 22:46:54 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.121 34:e8:94:bc:91:8e
Tue Apr 20 22:46:54 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.121 34:e8:94:bc:91:8e DESKTOP-TOA4R9P
Tue Apr 20 23:03:24 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.241 34:20:03:59:99:5a
Tue Apr 20 23:03:24 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.241 34:20:03:59:99:5a
Wed Apr 21 00:02:28 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 34:20:03:51:66:f3
Wed Apr 21 00:02:28 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.205 34:20:03:51:66:f3
Wed Apr 21 00:02:28 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.205 34:20:03:51:66:f3
Wed Apr 21 00:02:28 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.205 34:20:03:51:66:f3
Wed Apr 21 00:03:25 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) a8:bb:50:86:7d:3b
Wed Apr 21 00:03:25 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.137 a8:bb:50:86:7d:3b
Wed Apr 21 00:03:25 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.137 a8:bb:50:86:7d:3b
Wed Apr 21 00:03:25 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.137 a8:bb:50:86:7d:3b wiz_867d3b
Wed Apr 21 00:03:25 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) a8:bb:50:82:54:6e
Wed Apr 21 00:03:25 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.159 a8:bb:50:82:54:6e
Wed Apr 21 00:03:25 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.159 a8:bb:50:82:54:6e
Wed Apr 21 00:03:25 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.159 a8:bb:50:82:54:6e wiz_82546e
Wed Apr 21 00:32:51 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 34:20:03:51:60:ed
Wed Apr 21 00:32:51 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.206 34:20:03:51:60:ed
Wed Apr 21 00:32:51 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.206 34:20:03:51:60:ed
Wed Apr 21 00:32:51 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.206 34:20:03:51:60:ed
Wed Apr 21 00:42:25 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.232 f0:18:98:3b:10:71
Wed Apr 21 00:42:25 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.232 f0:18:98:3b:10:71 Allissas-MBP
Wed Apr 21 01:34:35 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 34:20:03:52:0c:bc
Wed Apr 21 01:34:35 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.195 34:20:03:52:0c:bc
Wed Apr 21 01:34:35 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.195 34:20:03:52:0c:bc
Wed Apr 21 01:34:35 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.195 34:20:03:52:0c:bc
Wed Apr 21 01:34:39 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 34:20:03:59:99:5a
Wed Apr 21 01:34:39 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.241 34:20:03:59:99:5a
Wed Apr 21 01:34:39 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.241 34:20:03:59:99:5a
Wed Apr 21 01:34:39 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.241 34:20:03:59:99:5a
Wed Apr 21 01:45:43 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 34:20:03:51:60:ed
Wed Apr 21 01:45:43 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.206 34:20:03:51:60:ed
Wed Apr 21 01:45:43 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.206 34:20:03:51:60:ed
Wed Apr 21 01:45:43 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.206 34:20:03:51:60:ed
Wed Apr 21 02:55:17 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 7c:72:e4:02:0a:e2
Wed Apr 21 02:55:17 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.216 7c:72:e4:02:0a:e2
Wed Apr 21 02:55:17 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.216 7c:72:e4:02:0a:e2
Wed Apr 21 02:55:17 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.216 7c:72:e4:02:0a:e2
Wed Apr 21 02:57:08 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 7c:72:e4:02:0a:e2
Wed Apr 21 02:57:08 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.216 7c:72:e4:02:0a:e2
Wed Apr 21 02:57:08 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.216 7c:72:e4:02:0a:e2
Wed Apr 21 02:57:08 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.216 7c:72:e4:02:0a:e2
Wed Apr 21 03:00:57 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.130 44:61:32:a1:67:17
Wed Apr 21 03:00:57 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.130 44:61:32:a1:67:17 Canteloupe-Lemonade
Wed Apr 21 04:01:48 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 34:20:03:51:66:f3
Wed Apr 21 04:01:48 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.205 34:20:03:51:66:f3
Wed Apr 21 04:01:48 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.205 34:20:03:51:66:f3
Wed Apr 21 04:01:48 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.205 34:20:03:51:66:f3
Wed Apr 21 04:11:09 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.143 a4:11:62:77:02:cf
Wed Apr 21 04:11:09 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.143 a4:11:62:77:02:cf VMB4500
Wed Apr 21 06:08:38 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 34:20:03:51:66:f3
Wed Apr 21 06:08:38 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.205 34:20:03:51:66:f3
Wed Apr 21 06:08:38 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.205 34:20:03:51:66:f3
Wed Apr 21 06:08:38 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.205 34:20:03:51:66:f3
Wed Apr 21 06:16:36 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 34:20:03:51:66:f3
Wed Apr 21 06:16:36 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.205 34:20:03:51:66:f3
Wed Apr 21 06:16:36 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.205 34:20:03:51:66:f3
Wed Apr 21 06:16:36 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.205 34:20:03:51:66:f3
Wed Apr 21 07:19:25 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.195 34:20:03:52:0c:bc
Wed Apr 21 07:19:25 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.195 34:20:03:52:0c:bc
Wed Apr 21 07:22:20 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.241 34:20:03:59:99:5a
Wed Apr 21 07:22:20 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.241 34:20:03:59:99:5a
Wed Apr 21 07:30:04 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.206 34:20:03:51:60:ed
Wed Apr 21 07:30:04 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.206 34:20:03:51:60:ed
Wed Apr 21 07:43:12 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.232 f0:18:98:3b:10:71
Wed Apr 21 07:43:12 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.232 f0:18:98:3b:10:71 Allissas-MBP
Wed Apr 21 07:54:06 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 34:20:03:59:99:5a
Wed Apr 21 07:54:06 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.241 34:20:03:59:99:5a
Wed Apr 21 07:54:06 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.241 34:20:03:59:99:5a
Wed Apr 21 07:54:06 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.241 34:20:03:59:99:5a
Wed Apr 21 08:16:23 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 34:20:03:51:66:f3
Wed Apr 21 08:16:23 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.205 34:20:03:51:66:f3
Wed Apr 21 08:16:23 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.205 34:20:03:51:66:f3
Wed Apr 21 08:16:23 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.205 34:20:03:51:66:f3
Wed Apr 21 08:23:57 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.130 44:61:32:a1:67:17
Wed Apr 21 08:23:57 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.130 44:61:32:a1:67:17 Canteloupe-Lemonade
Wed Apr 21 08:57:08 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.216 7c:72:e4:02:0a:e2
Wed Apr 21 08:57:08 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.216 7c:72:e4:02:0a:e2
Wed Apr 21 09:55:19 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 34:20:03:52:0c:bc
Wed Apr 21 09:55:19 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.195 34:20:03:52:0c:bc
Wed Apr 21 09:55:19 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.195 34:20:03:52:0c:bc
Wed Apr 21 09:55:19 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.195 34:20:03:52:0c:bc
Wed Apr 21 10:05:57 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 34:20:03:51:60:ed
Wed Apr 21 10:05:57 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.206 34:20:03:51:60:ed
Wed Apr 21 10:05:57 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.206 34:20:03:51:60:ed
Wed Apr 21 10:05:57 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.206 34:20:03:51:60:ed
Wed Apr 21 10:11:09 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.143 a4:11:62:77:02:cf
Wed Apr 21 10:11:09 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.143 a4:11:62:77:02:cf VMB4500
Wed Apr 21 12:44:21 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 7c:72:e4:02:0a:e2
Wed Apr 21 12:44:21 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.216 7c:72:e4:02:0a:e2
Wed Apr 21 12:44:21 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.216 7c:72:e4:02:0a:e2
Wed Apr 21 12:44:21 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.216 7c:72:e4:02:0a:e2
Wed Apr 21 13:22:07 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.232 f0:18:98:3b:10:71
Wed Apr 21 13:22:07 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.232 f0:18:98:3b:10:71 Allissas-MBP
Wed Apr 21 13:30:14 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 7c:72:e4:02:0a:e2
Wed Apr 21 13:30:14 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.216 7c:72:e4:02:0a:e2
Wed Apr 21 13:30:14 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.216 7c:72:e4:02:0a:e2
Wed Apr 21 13:30:14 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.216 7c:72:e4:02:0a:e2
Wed Apr 21 13:35:46 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.241 34:20:03:59:99:5a
Wed Apr 21 13:35:46 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.241 34:20:03:59:99:5a
Wed Apr 21 14:00:34 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.130 44:61:32:a1:67:17
Wed Apr 21 14:00:34 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.130 44:61:32:a1:67:17 Canteloupe-Lemonade
Wed Apr 21 14:01:47 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.205 34:20:03:51:66:f3
Wed Apr 21 14:01:47 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.205 34:20:03:51:66:f3
Wed Apr 21 14:48:27 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 34:20:03:51:60:ed
Wed Apr 21 14:48:27 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.206 34:20:03:51:60:ed
Wed Apr 21 14:48:27 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.206 34:20:03:51:60:ed
Wed Apr 21 14:48:27 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.206 34:20:03:51:60:ed
Wed Apr 21 15:20:17 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 34:20:03:51:66:f3
Wed Apr 21 15:20:17 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.205 34:20:03:51:66:f3
Wed Apr 21 15:20:17 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.205 34:20:03:51:66:f3
Wed Apr 21 15:20:17 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.205 34:20:03:51:66:f3
Wed Apr 21 15:37:46 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.195 34:20:03:52:0c:bc
Wed Apr 21 15:37:46 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.195 34:20:03:52:0c:bc
Wed Apr 21 15:58:46 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) a8:bb:50:86:7d:3b
Wed Apr 21 15:58:46 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.137 a8:bb:50:86:7d:3b
Wed Apr 21 15:58:49 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) a8:bb:50:82:54:6e
Wed Apr 21 15:58:49 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.159 a8:bb:50:82:54:6e
Wed Apr 21 15:58:49 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) a8:bb:50:86:7d:3b
Wed Apr 21 15:58:49 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.137 a8:bb:50:86:7d:3b
Wed Apr 21 15:58:49 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.137 a8:bb:50:86:7d:3b
Wed Apr 21 15:58:49 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.137 a8:bb:50:86:7d:3b wiz_867d3b
Wed Apr 21 15:58:49 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.159 a8:bb:50:82:54:6e
Wed Apr 21 15:58:49 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.159 a8:bb:50:82:54:6e wiz_82546e
Wed Apr 21 16:10:02 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 34:20:03:59:99:5a
Wed Apr 21 16:10:02 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.241 34:20:03:59:99:5a
Wed Apr 21 16:10:02 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.241 34:20:03:59:99:5a
Wed Apr 21 16:10:02 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.241 34:20:03:59:99:5a
Wed Apr 21 16:11:09 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.143 a4:11:62:77:02:cf
Wed Apr 21 16:11:09 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.143 a4:11:62:77:02:cf VMB4500
Wed Apr 21 17:23:22 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 192.168.8.181 98:48:27:b0:46:54
Wed Apr 21 17:23:22 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.181 98:48:27:b0:46:54
Wed Apr 21 17:23:22 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.181 98:48:27:b0:46:54
Wed Apr 21 17:23:22 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.181 98:48:27:b0:46:54 DESKTOP-96L49GF
Wed Apr 21 18:15:58 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 34:20:03:52:0c:bc
Wed Apr 21 18:15:58 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.195 34:20:03:52:0c:bc
Wed Apr 21 18:15:58 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.195 34:20:03:52:0c:bc
Wed Apr 21 18:15:58 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.195 34:20:03:52:0c:bc
Wed Apr 21 18:38:16 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 34:20:03:59:99:5a
Wed Apr 21 18:38:16 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.241 34:20:03:59:99:5a
Wed Apr 21 18:38:16 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.241 34:20:03:59:99:5a
Wed Apr 21 18:38:16 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.241 34:20:03:59:99:5a
Wed Apr 21 19:16:00 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 34:20:03:51:66:f3
Wed Apr 21 19:16:00 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.205 34:20:03:51:66:f3
Wed Apr 21 19:16:00 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.205 34:20:03:51:66:f3
Wed Apr 21 19:16:00 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.205 34:20:03:51:66:f3
Wed Apr 21 19:30:15 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.216 7c:72:e4:02:0a:e2
Wed Apr 21 19:30:15 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.216 7c:72:e4:02:0a:e2
Wed Apr 21 19:34:34 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.130 44:61:32:a1:67:17
Wed Apr 21 19:34:34 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.130 44:61:32:a1:67:17 Canteloupe-Lemonade
Wed Apr 21 20:07:05 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 34:20:03:51:60:ed
Wed Apr 21 20:07:05 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.206 34:20:03:51:60:ed
Wed Apr 21 20:07:05 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.206 34:20:03:51:60:ed
Wed Apr 21 20:07:05 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.206 34:20:03:51:60:ed
Wed Apr 21 20:27:52 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.232 f0:18:98:3b:10:71
Wed Apr 21 20:27:52 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.232 f0:18:98:3b:10:71 Allissas-MBP
Wed Apr 21 20:35:47 2021 daemon.info dnsmasq-dhcp[3472]: DHCPDISCOVER(br-lan) 192.168.8.121 34:e8:94:bc:91:8e
Wed Apr 21 20:35:47 2021 daemon.info dnsmasq-dhcp[3472]: DHCPOFFER(br-lan) 192.168.8.121 34:e8:94:bc:91:8e
Wed Apr 21 20:35:47 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.121 34:e8:94:bc:91:8e
Wed Apr 21 20:35:47 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.121 34:e8:94:bc:91:8e DESKTOP-TOA4R9P
Wed Apr 21 20:46:25 2021 daemon.info dnsmasq-dhcp[3472]: DHCPREQUEST(br-lan) 192.168.8.121 34:e8:94:bc:91:8e
Wed Apr 21 20:46:25 2021 daemon.info dnsmasq-dhcp[3472]: DHCPACK(br-lan) 192.168.8.121 34:e8:94:bc:91:8e DESKTOP-TOA4R9P
I connected to USB tether and it all went great then bam 1 hour later, phone tether option is greyed out, I checked tether to pc and it works fine.
Seriously how do I fix this? Read through this thread and is no help at all. Is USB 3 on Beryl dead now or ?
EDIT: Rebooted fixed it, but then it drops and cannot reconnect until I reboot again. So it appears to be on a one hour timer before it disconnects. How do I disable the disconnect timer? ( I will keep working on this till either i fix it or someone gives me an answer)
Ok, tried to paste iptables -t mangle -A POSTROUTING -j TTL --ttl-set 65 in firewall custom rules, we will see…
Ok, problem seems largely fixed now.
Just one small problem now, After about 12 hours of no problem, internet stop working but phone usb tether is still on (not greyed out) and tether connection in Beryl is still connected. Turning on and off airplane fixes it. Any idea why that happens?
Just wondering if the issue is now fixed with the latest firmware release for the Beryl? (openssl, etc?)
Thanks!
Yes already fixed in 3.201.
Thanks for this guide. I couldn’t make it to work without it. All that was needed was to change the WAN interface to tap-easytether. Works great with an LG v50 ThinkQ
and the config file
Help, everytime i try to install the ipk file i get an error saying that is not compatible with my architecture, makes no sense!
EDIT:
Nevermind, my error was, i choose MEDIATEK in the driver, because the webpage says pick your correct processor, but i had no idea my actual processor was under “ramips” folder, that one has the correct .ipk file for GL-MT1300 router!
Now it doesn’t work i have in my phone connection established but no internet access in the router. Neither 192.168.o.1 can i change the wan interface … Carrier-independent tethering for your Android phone. EasyTether shares Internet connection from your smartphone with your computer, tablet or router.
What did you enter in the 3g modem configuration?
