Hello, just see the following operation,
This issue is appearing after I upgraded to firmware 3.201, then I reversed firmware and reinstall luci, but still can not resolve this issue.
What should I do?
Thanks!
What should I do?
Thanks!
Finally, I installed luci by using opkg command.
root@GL-MT1300:~# opkg install luci
Installing luci (git-21.044.30835-34e0d65-1) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/luci_git-21.044.30835-34e0d65-1_all.ipk
Installing luci-proto-3g (git-21.044.30835-34e0d65-1) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/luci-proto-3g_git-21.044.30835-34e0d65-1_all.ipk
Installing luci-proto-qmi (git-21.044.30835-34e0d65-1) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/luci-proto-qmi_git-21.044.30835-34e0d65-1_all.ipk
Installing luci-proto-relay (git-21.044.30835-34e0d65-1) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/luci-proto-relay_git-21.044.30835-34e0d65-1_all.ipk
Installing luci-proto-ncm (git-21.044.30835-34e0d65-1) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/luci-proto-ncm_git-21.044.30835-34e0d65-1_all.ipk
Installing luci-proto-wireguard (git-21.044.30835-34e0d65-1) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/luci-proto-wireguard_git-21.044.30835-34e0d65-1_all.ipk
Installing uhttpd (2020-10-01-3abcc891-1) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/uhttpd_2020-10-01-3abcc891-1_mipsel_24kc.ipk
Installing lua (5.1.5-3) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/lua_5.1.5-3_mipsel_24kc.ipk
Installing luci-lib-nixio (git-21.044.30835-34e0d65-1) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/luci-lib-nixio_git-21.044.30835-34e0d65-1_mipsel_24kc.ipk
Installing luci-lib-ip (git-21.044.30835-34e0d65-1) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/luci-lib-ip_git-21.044.30835-34e0d65-1_mipsel_24kc.ipk
Installing rpcd (2020-05-26-67c8a3fd-1) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/rpcd_2020-05-26-67c8a3fd-1_mipsel_24kc.ipk
Installing libubus-lua (2019-12-27-041c9d1c-1) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/libubus-lua_2019-12-27-041c9d1c-1_mipsel_24kc.ipk
Installing luci-lib-jsonc (git-21.044.30835-34e0d65-1) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/luci-lib-jsonc_git-21.044.30835-34e0d65-1_mipsel_24kc.ipk
Installing liblucihttp0 (2019-07-05-a34a17d5-1) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/liblucihttp0_2019-07-05-a34a17d5-1_mipsel_24kc.ipk
Installing liblucihttp-lua (2019-07-05-a34a17d5-1) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/liblucihttp-lua_2019-07-05-a34a17d5-1_mipsel_24kc.ipk
Installing rpcd-mod-file (2020-05-26-67c8a3fd-1) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/rpcd-mod-file_2020-05-26-67c8a3fd-1_mipsel_24kc.ipk
Installing rpcd-mod-luci (20201107) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/rpcd-mod-luci_20201107_mipsel_24kc.ipk
Installing cgi-io (19) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/cgi-io_19_mipsel_24kc.ipk
Installing luci-base (git-21.044.30835-34e0d65-1) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/luci-base_git-21.044.30835-34e0d65-1_mipsel_24kc.ipk
Installing luci-mod-status (git-21.044.30835-34e0d65-1) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/luci-mod-status_git-21.044.30835-34e0d65-1_mipsel_24kc.ipk
Installing luci-mod-system (git-21.044.30835-34e0d65-1) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/luci-mod-system_git-21.044.30835-34e0d65-1_all.ipk
Installing rpcd-mod-iwinfo (2020-05-26-67c8a3fd-1) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/rpcd-mod-iwinfo_2020-05-26-67c8a3fd-1_mipsel_24kc.ipk
Installing luci-mod-network (git-21.044.30835-34e0d65-1) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/luci-mod-network_git-21.044.30835-34e0d65-1_all.ipk
Installing luci-mod-admin-full (git-21.044.30835-34e0d65-1) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/luci-mod-admin-full_git-21.044.30835-34e0d65-1_all.ipk
Installing luci-theme-bootstrap (git-21.044.30835-34e0d65-1) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/luci-theme-bootstrap_git-21.044.30835-34e0d65-1_all.ipk
Installing luci-app-firewall (git-21.044.30835-34e0d65-1) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/luci-app-firewall_git-21.044.30835-34e0d65-1_all.ipk
Installing luci-app-opkg (git-21.044.30835-34e0d65-1) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/luci-app-opkg_git-21.044.30835-34e0d65-1_all.ipk
Installing luci-proto-ppp (git-21.044.30835-34e0d65-1) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/luci-proto-ppp_git-21.044.30835-34e0d65-1_all.ipk
Installing luci-proto-ipv6 (git-21.044.30835-34e0d65-1) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/luci-proto-ipv6_git-21.044.30835-34e0d65-1_all.ipk
Installing rpcd-mod-rrdns (20170710) to root...
Downloading https : //fw. gl-inet. com/releases/v19.07.7/packages-3.0/ramips/packages/rpcd-mod-rrdns_20170710_mipsel_24kc.ipk
Configuring luci-proto-wireguard.
Configuring liblucihttp0.
Configuring cgi-io.
Configuring luci-app-opkg.
Configuring rpcd.
Configuring luci-lib-ip.
Configuring libubus-lua.
Configuring lua.
Configuring luci-lib-nixio.
Configuring luci-lib-jsonc.
Configuring liblucihttp-lua.
Configuring rpcd-mod-file.
Configuring rpcd-mod-luci.
Configuring luci-base.
Configuring luci-mod-system.
Configuring luci-theme-bootstrap.
Configuring luci-mod-status.
Configuring luci-app-firewall.
Configuring luci-proto-3g.
Configuring luci-proto-qmi.
Configuring luci-proto-ppp.
Configuring rpcd-mod-iwinfo.
Configuring luci-mod-network.
Configuring luci-mod-admin-full.
Configuring luci-proto-ipv6.
Configuring luci-proto-relay.
Configuring luci-proto-ncm.
Configuring uhttpd.
4+0 records in
4+0 records out
Generating a RSA private key
writing new private key to '/etc/uhttpd.key.new'
Configuring rpcd-mod-rrdns.
Configuring luci.
root@GL-MT1300:~#
The issue still exists in 3.023. I tried to use the admin page in the GL.iNet interface and got a failed message. Afterward the page gave me a link to it, but would open it. I SSH’d into the device and used the opkg command, which installed it. It still requires clicking on a link on the ‘Advanced’ page, but it brings up the Luci interface now.
In 3.203 the link to Lucy (from “Advanced”) takes the protocol of the surrounding page.
If you have the gli-net page open with http, also lucy will open in http and not in https.
Try if you can open the link in https.
