I’m familiar with gl.inet & OpenWRT, but looks like Beryl firmware is lacking access to luci/advanced settings. Sadly, this makes the router of no use to me as I need to set custom firewall rules. If I manually enter the url for advanced setting, eg, 192.168.8.1/cgi-bin/luci it redirects to the basic settings gui. Is there a workaround? Is more advanced firmware in the pipeline? Might need to return it, otherwise which makes me sad as I love my little Mango and had high hopes for Beryl.
I read the manual but I’m still having the same problem. I hit the update button and then searched for ‘luci’ but I don’t see it listed. I do see ‘luci-proto-wireguard’ listed as installed but no “advanced” menu.
I can’t get luci to install - already upgraded firmware and can find Luci in the package repository, but get this error every time. Any ideas folks? I have internet and can download the package if I use the link in the message below, but the install is failing.
Edit: Figured it out - it wasn’t working properly through my phone hotspot or tethered connection. Once I connected to my neighbor’s WIFI, it downloaded and installed Luci successfully. Awesome!
