Gl- mt1300 (beryl) scan no networks found
While trying to figure out why my MT1300 does not show my 5G wifi I found out that when I enable channel 12 and 13 (all channels) for 2.4G on my router, MT1300 does not find my 2.4G wifi either !
So maybe try playing with enabled/disabling channels on your router.
I am still looking for a fix for 5G, tried different settings but no luck. MT1300 does see other 5G wifi just not mine.
MT1300 is running firmware 3.203.
Can you check if your 5G wifi is using DFS channels? MT1300 does not connect to DFS channels
Sure if you tell me how :slight_smile:
I have no option like that in router webif (ZXHN H267A V1.0).
If you have a windows pc, you can connect to that wifi and check what channel it is using.
Untitled
screenshot of router 5g settings, I didn’t customize those are defaults but I need to select ‘customize’ to show them
got it to show up with these settings, I can enable Band 2 too.
what I find weird is that other 5G show up with channels I had to disable though
#iwinfo ra0 scan
Cell 01 - Address: D4:58:xxxxxx
          ESSID: "Aifxxxxxx"
          Mode: Master  Channel: 40
          Signal: 34 %  Quality: 34/100
          Encryption: mixed WPA/WPA2 PSK (CCMP)
          HT Capabilities: UNKNOW
Cell 02 - Address: CC:50:xxxxxx
          ESSID: "Ixxxxxx"
          Mode: Master  Channel: 48
          Signal: 20 %  Quality: 20/100
          Encryption: mixed WPA/WPA2 PSK (NONE)
Cell 03 - Address: 94:46:xxxxxx
          ESSID: "Savxxxxxx"
          Signal: 10 %  Quality: 10/100
          Encryption: WPA2 PSK (NONE)
Can you change channel to
36-48
and
149-161
Channel 64 is DFS channel and the router does not support
with these settings my 5G wifi shows up as well.
Anyways something that is advertised as travel router should be able to find 2.4G and 5G wifis regardless of setting, as one usually has no access to e.g. hotel routers to change some settings :wink:
Same issue here on version 3.21.
No networks
Keep scanning and rebooting
no help.
This looks like a waste of money.
firmware 3.21??
Pls post as new thread with details of your issue rather than reply an old post.
