I have my iPhone connected via wifi to Beryl
But Beryl is saying there is no tethering but the phone is connected to the device…
what am i doing wrong?
I have iphone connected through hotspot using the passcode
I then did a USB connection but not needed because i was already wifi enabled…
still no tethering…no connection…nothing
I cannot understand.
Are you connecting your iphone to Beryl via USB cable?
If you want to share your iphone’s Internet to Beryl via USB cable, you need to set up using another device, because when you enable hotspot, iphone’s wifi will be disconnected from Beryl automatically.
In Beryl’s UI you should see Tethering device.
I turn on tethering for iPhone via WiFi and leave the phone next to the router
I connect beryl to the iPhone to get internet access and it found iPhone device but no connection to the internet?
On my desktop I scanned the WiFi network and connect to beryl but again no internet because beryl does not connect to tethering
This is by wifi, right? Does the UI say connected successfully or failed? Does it show IP address? Pls send screenshot.
I am connected to tethering because iphone states i am
Beryl connects my iphone device but does not recognise any internet connection and the tethering does not show up
The UI seems just normal. So you mean the when connected to the router, still does not have Internet?
Are you able to ping google.com
Pinging google.com [216.58.212.206] with 32 bytes of data:
Reply from 216.58.212.206: bytes=32 time=51ms TTL=112
Reply from 216.58.212.206: bytes=32 time=36ms TTL=112
Reply from 216.58.212.206: bytes=32 time=29ms TTL=112
Reply from 216.58.212.206: bytes=32 time=50ms TTL=112
Ping statistics for 216.58.212.206:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 29ms, Maximum = 51ms, Average = 41ms
Are you doing this when connected to Beryl? Seems it is just normal
