GL-MT1300 Beryl will not connect to network in repeater mode
Hi there,
I’m seemingly unable to connect to my network in repeater mode. I select the SSID and input the password, click join, and then the spinner shows for around 10 seconds before apparently timing out, at which point my laptop loses connection to the router.
I believe this is the relevant part of the logs:
Sun Dec 12 15:35:14 2021 user.info : gl_health start->
Sun Dec 12 15:36:52 2021 user.info : saved ssid ignore: VM7890183 0
Sun Dec 12 15:36:52 2021 user.info : [  810] gl-sdk>> bIsSaved=0, ssid=VM7890183, encryption=psk2, bssid=D8:0D:17:7B:33:4E, wds=0, device=mt7615e2, identity=, channel=6
Sun Dec 12 15:36:53 2021 user.info : [ 2972] gl-wifi-core>> bIsStaEnabled=1
Sun Dec 12 15:36:57 2021 daemon.info dnsmasq-dhcp[2832]: DHCPREQUEST(br-lan) 192.168.8.246 e4:42:a6:fb:f1:26
Sun Dec 12 15:36:57 2021 daemon.info dnsmasq-dhcp[2832]: DHCPACK(br-lan) 192.168.8.246 e4:42:a6:fb:f1:26 iamnotacrook
Sun Dec 12 15:37:18 2021 user.info : [  817] gl-sdk>> wifi_join return=-5, channel=-1
Sun Dec 12 15:37:18 2021 user.info : [ 1893] gl-wifi-core>> Restart wifi...
Sun Dec 12 15:37:19 2021 daemon.notice netifd: Network device 'ra0' link is down
Sun Dec 12 15:37:19 2021 daemon.notice netifd: Network device 'rax0' link is down
Sun Dec 12 15:37:34 2021 daemon.notice netifd: Network device 'ra0' link is up
Sun Dec 12 15:37:35 2021 daemon.notice netifd: Network device 'rax0' link is up
Sun Dec 12 15:37:38 2021 daemon.info dnsmasq-dhcp[2832]: DHCPREQUEST(br-lan) 192.168.8.246 e4:42:a6:fb:f1:26
Sun Dec 12 15:37:38 2021 daemon.info dnsmasq-dhcp[2832]: DHCPACK(br-lan) 192.168.8.246 e4:42:a6:fb:f1:26 iamnotacrook
This is essentially brand new out of the box, and the only configuration I’ve done apart from changing the default password is connecting to the router via ethernet so that I could download and install luci (which I did through the GL iNet admin GUI).
Any pointers would be appreciated
I was having similar issues once updated to the beta2 version, it’s been smooth sailing for the repeater mode connections at multiple locations.
https://dl.gl-inet.com/firmware/snapshots/3.211_beta2/mt1300-newdriver/
Same smooth sailing here on my Beryl.
Thanks for the idea but I’m still unable to connect in repeater mode and I can now no longer access the advanced settings for the logs.
You do not have this problem in old firmware e.g. 3.203?
I just verified and I cannot find some 2.4G SSID when using the beta firmware. I have filed a bug.
Update: Tested again and the problem disappear. Will investigate further.
Hi Alzhao. I’m afraid I cannot connect to the network in repeater mode in either firmware, and have tried connecting to both 2.4 and 5ghz networks.
I downgraded to the original firmware using the revert page, then reinstalled the beta and reinstalled luci.I then tried to connect in repeater mode again. Attempt 1 resulted in a timeout error flash/toast/whatever you want to call it at the top of the screen, followed by wireless connection to the router being lost. When I reconnected I tried to scan again but received no results. I then rebooted and, while I was able to scan for access points successfully, I received the same timeout error when I tried to connect
Progress, maybe? I’ve included the latest version of my logs (pastebin link).
Also, if anyone is able to connect me to the official support (unless this is it?) I’d appreciate it.
I tested further and actually it works normal in my side.
Can you give more details of your scenario? Is this a public wifi or hotel?
This is community support. If you want official support you can use email to support@gl-inet.com
But I think here is OK as I called developer to check your log.
Hello, please show me the WLAN config.
cat /etc/config/wireless
@alzhao Thanks for providing the support email. I’ll try to keep it to community support for now though, in case it helps someone else.
This is on a private residential WiFi network where I am trying to test the device before travelling. I’m using a Virgin Media Home Hub 3 provided by my ISP - this set up is similar to around 24% of the UK according to latest market research stats. I have no custom configurations, and no existing repeaters on the network.
@JerryZhao WLAN config as follows (I’ve replaced my password with PassWord, but that’s the only change)
root@GL-MT1300:~# cat /etc/config/wireless
config wifi-device 'mt7615e5'
        option txantenna '2'
        option rxantenna '2'
        option hwmode '11ac'
        option htmode 'VHT80'
        option country 'CN'
        option txpower '20'
        option band '5G'
        option region '0'
        option aregion '10'
        option noscan '1'
        option disabled '0'
        option type 'mtk'
        option cfg '/etc/wireless/mt7615_5g.dat'
        option channel '44'
config wifi-iface 'wifi5g'
        option device 'mt7615e5'
        option network 'lan'
        option mode 'ap'
        option encryption 'psk2'
        option ssid 'GL-MT1300-a12-5G'
        option key 'goodlife'
        option disassoc_low_ack '0'
        option ifname 'ra0'
        option wds '1'
        option disabled '0'
config wifi-device 'mt7615e2'
        option htmode 'HT40'
        option country 'CN'
        option txpower '20'
        option band '2G'
        option region '0'
        option aregion '10'
        option noscan '1'
        option hwmode '11ng'
        option disabled '0'
        option channel '6'
        option type 'mtk'
        option cfg '/etc/wireless/mt7615_2g.dat'
config wifi-iface 'wifi2g'
        option device 'mt7615e2'
        option mode 'ap'
        option ssid 'GL-MT1300-a12'
        option wds '1'
        option ifname 'rax0'
        option disabled '0'
config wifi-iface 'guest5g'
        option network 'guest'
        option mode 'ap'
        option wds '1'
        option ssid 'GL-MT1300-a12-Guest-5G'
        option ifname 'ra1'
        option disabled '1'
        option guest '1'
config wifi-iface 'guest2g'
        option mode 'ap'
        option wds '1'
        option ssid 'GL-MT1300-a12-Guest'
        option ifname 'rax1'
        option disabled '1'
        option guest '1'
config wifi-iface 'sta'
        option network 'wwan'
        option mode 'sta'
        option ifname 'apcli0'
        option ssid 'VM7890183'
        option channel '44'
        option key 'PassWord'
        option disabled '1'
I did not know this. I thought the advice and help here was so direct and good that this was official support, with the help of some others. In fact, I thought you were official support. :grinning:
You are right. The is mainly maintained by GL.iNet. But some other users are helping. Email support is private and more trackable. In the forum I may just missed a lot of things.
@JerryZhao I don’t suppose the WLAN config provided any information? Is there something I should be looking at in here?
The config looks fine.
