Unpacked my GL-MT1300, connected the power, connected via wi-fi to GL-MT1300-ba1. Tried to connect to http://192.168.8.1, got " 192.168.8.1 took too long to respond" error. Tried a direct LAN connection - same thing. Disabled my security software on Windows - same error. Tried resetting the router to factory defaults, same error. I must be overlooking something.
If it says took to long to respound means it is still starting up so give it 5min I would say. It if is connected to a WAN it should setup pretty quickly and you get a solid White light. If it is not connected will flash blue and tack a little bit because of no dhcp.
Once the error message comes up after about 2 minutes of trying, the browser stops trying to connect. I can wait an hour and nothing further will happen. The unit is flashing a slow blue. I don’t know what “tack a little bit” means.
The private browser window doesn’t redirect to anywhere. It just comes back with a message that the ip address took too long to respond after about 1 minute.
The ipconfig for the LAN adapter shows a blank DHCP address. - even after I do the flushdns
The solution was much simpler. I had my ethernet cable plugged into the WAN port on the device instead of a LAN port. Once I corrected that I was able to connect to the set up screen and get logged in to my main wireless network.
Then on my laptop I was able to connect with the MT1300 wireless SSID with no problem. I have been running on it for about an hour now with no issues.
However, on my desktop, when I try to connect to the same MT1300 SSID that is working on my laptop, I got connected, but the status in Windows says No Internet. Why is the same SSID working on one computer but not on the other?
