I am wanting to take off the case so that i can add my external antennas instead of using the plastic ones that are currently on it.
I see on the FCC screenshots that it looks to only have 4 screws:
When I take out all 4 screws it still does not “feel” like it can just lift off the top as its shown in the above image?
Are there tabs I need to dislodge in order for the top to come off?
I too am known to void warranties. Run a splugder or guitar pick around the seams. See where you encounter resistance.
… a little Dremel action always hurts anything.
Looking carefully, there are 2 catches on each side, which is pretty standard. I would first try squeezing the half on the right to try to release the catch. If that does not work, I would use a spudger or a screwdriver (!!) in a pinch.
Yeah, it can’t be that difficult. The boys over on CNX were able to do it on a Beryl AX. They were even kind enough to leave the tool used in the shot:
Thanks for that, @bring.fringe18
