I have tried turning off and on the 2.4ghz wifi and it won’t broadcast. It was working with the default name as soon as I changed it, it stopped broadcasting the SSID. The SSID is visible and not hidden. I am on the latest testing firmware. Any ideas?
Is the band set to automatic? Try going into wireless and changing the band to something between 1 and 13
Welp, that fixed it. Changed it from automatic to 8. And popped right up. Thank you!
