The documentation for the GL-MT1300 states that the Pantech UML290 Verizon USB modem is supported and tested by “GL.iNet/steven”
Can someone from GLiNet, steven (or the community) please provide the settings that need to be specified? I’ve read the other posts and nothing works, yet it says it was tested, so somebody out there must have the proper device settings to make it work.
Thanks!
alzhao
March 24, 2022, 7:04am
#2
It should work in QMI mode.
If you have more info pls let me know.
I don’t have any more info, can you provide a configuration for the network config?
alzhao
March 24, 2022, 11:03am
#4
I don’t have the modem. It should be simple QMI config.
If it does not work for you, pls send screenshot and logs to investigate.
config:
config interface 'modem_1_1'
option ifname 'wwan0'
option service 'umts'
option apn 'VZWINTERNET'
option proto 'qmi'
option device '/dev/cdc-wdm0'
option node '1-1:1.5'
option auth 'NONE'
option metric '40'
option disabled '0'
logs
Thu Mar 24 11:04:03 2022 daemon.notice netifd: Interface 'modem_1_1' is setting up now
Thu Mar 24 11:04:03 2022 user.notice root: modem_1_1 interface miss
Thu Mar 24 11:04:03 2022 daemon.notice netifd: modem_1_1 (13294): Waiting for SIM initialization
Thu Mar 24 11:04:03 2022 daemon.notice netifd: modem_1_1 (13294): PIN verification is disabled
Thu Mar 24 11:04:03 2022 daemon.notice netifd: modem_1_1 (13294): Waiting for network registration
Thu Mar 24 11:04:03 2022 daemon.notice netifd: modem_1_1 (13294): Starting network modem_1_1
Thu Mar 24 11:04:03 2022 daemon.notice netifd: modem_1_1 (13294): Unable to connect IPv4
Thu Mar 24 11:04:03 2022 daemon.notice netifd: modem_1_1 (13342): Stopping network modem_1_1
Thu Mar 24 11:04:03 2022 daemon.notice netifd: modem_1_1 (13342): Command failed: Permission denied
Thu Mar 24 11:04:03 2022 daemon.notice netifd: Interface 'modem_1_1' is now down
Thu Mar 24 11:04:04 2022 daemon.notice netifd: modem_1_1 (13362): Waiting for SIM initialization
Thu Mar 24 11:04:04 2022 daemon.notice netifd: modem_1_1 (13362): PIN verification is disabled
Thu Mar 24 11:04:04 2022 daemon.notice netifd: modem_1_1 (13362): Waiting for network registration
Thu Mar 24 11:04:04 2022 daemon.notice netifd: modem_1_1 (13362): Starting network modem_1_1
Thu Mar 24 11:04:04 2022 daemon.notice netifd: modem_1_1 (13362): Unable to connect IPv4
Thu Mar 24 11:04:04 2022 daemon.notice netifd: modem_1_1 (13583): Stopping network modem_1_1
Thu Mar 24 11:04:04 2022 daemon.notice netifd: modem_1_1 (13583): Command failed: Permission denied
Thu Mar 24 11:04:04 2022 daemon.notice netifd: Interface 'modem_1_1' is now down
alzhao
March 24, 2022, 11:12am
#6
Does your SIM need to work with IPV6?
I don’t know, maybe, if so what should I try?
alzhao
March 25, 2022, 4:38am
#8
yes pls just try and see.
? again, what is the configuration attribute/value I should be using here?
alzhao
March 26, 2022, 4:06am
#10
Try to enabled ipv6 in more settings->ipv6
and check
Were you able to get this solved? I just ordered a modem and wanted to know if this was going to work as a plug n play solution…
