I recently purchased the GL-MT1300 but was not able to get StrongVPN’s OpenVPN Config files to work. From the StrongVPN Intranet, only Config files for Windows or Linux/Mac are available for download. I’ve tried both and both failed to connect. (See attached screenshot)
Is there another format I can download from StrongVPN?
I’ve also tried adding StrongVPN using the GL-inet iPhone App and kept on getting “Invalid Username Format Provided” error.
I followed this setup guide and still didn’t work.
StrongVPN support did get back to me and said for OpenVPN connections from Hong Kong and China, will need the SCRAMBLE function which isn’t supported by GL-iNet routers. So will need to stick to the WireGuard protocol, which works fine.
