Hello everyone,
I am using a GL-MT2500 Brume 2 with Wireguard-Connection to ProtonVPN. The Brume 2 is connected to a FritzBox 6660 in Bridge mode an gets it’s own global IP address. I loose continually (1-2 times per day) the internet connection and have to manually connect again with the Wireguard server. After that it will work again for a while.
Why does the Brume 2 loose his connection to ProtonVPN? I tried several configs and servers but same problem.
Can you help?
I have almost the same setup using an MT2500 as a Proton VPN client with a slight difference: I’ve set the WAN IP as static instead from DHCP as I was having issues sometimes.
Also in the [peer] section of the Proton client config make sure you have : PersistentKeepalive = 25.
I also reboot automatically the router once a week at night
