I am wondering if I can upgrade my router using luci-app-attendedsysupgrade or AUC to keep my app and settings after firmware upgrade? when search firmware from openwrt.org for GL-MT2500, I only see a snapshot version. Should there be a stable version? Thanks!
https://firmware-selector.openwrt.org/?version=SNAPSHOT&target=mediatek%2Ffilogic&id=glinet_gl-mt2500
Seems to only be available on SNAPSHOT, it was added in November 2023:
committed 07:02AM - 27 Nov 23 UTC
Hardware
SoC: MediaTek MT7981BA
RAM: 1GB DDR4 (NANYA NT5AD512M16C4-JR… )
MMC: 8GB eMMC (Samsung 8GTF4R)
ETH: 1000Base-T LAN (ePHY)
2500Base-T WAN (MaxLinear GPY211C)
BTN: 1x Reset Button
LED: System (blue/white)
VPN (white)
USB: 1x USB-A (USB 3.0)
UART: 115200 8N1 - Pinout on board next to LAN port
Don't connect 3.3V!
Known Issues
U-Boot vendor recovery does not seem to accept any images, neither
GL.iNet images nor OpenWrt images. Recovery requires serial access!
Installation
Upload the OpenWrt sysupgrade image to the Gl.iNet Web-UI. Make sure to
not retain existing settings.
Signed-off-by: David Bauer <[email protected] >
It should have been included in 23.05.3 unless it failed to build
bruce
June 6, 2024, 10:15am
3
Can find the stable version firmware in GL download center:
https://dl.gl-inet.com/router/mt2500/
