GL-MT2500 Max VPN connection
Has anyone here tested the GL-MT2500 Max VPN connection, either with OpenVPN or WireGuard? Can I assume that the official website’s stated throughput of 355 Mbps for WireGuard when VPN-connected means it can support up to 100 connections, assuming each connection uses 3 Mbps?
If more VPN connections are needed, what is the hardware bottleneck - the CPU or the RAM?
Do you mean the max vpn client of GL-MT2500’s vpn server?
yup, max connections the device can support.
