What I want is not to force OpenVPN server to be default gateway but serve push routes only Subnets I want
Currently if I Iedit this config file it is gets overwritten.
cat /tmp/ovpnserver/ovpnserver
persist-key
persist-tun
auth SHA256
cipher AES-256-GCM
ncp-disable
dev ovpnserver
dev-type tun
group nogroup
keepalive 10 120
mode server
mute 5
port 1194
proto udp
push “persist-key”
push “persist-tun”
push “redirect-gateway def1”
route-gateway dhcp
topology subnet
duplicate-cn
user nobody
mark 524288
verb 3
server 10.19.0.0 255.255.255.0
So what I want to be able to remove
route-gateway dhcp
lines and add push route lines for 2 subnets I want.
