GL-MT2500A Wan issues openwrt
Hello All,
I have been reading all over the interweb, but haven’t found anything related.
What I want is to get a working version of openwrt 24 and upwards on it so I can use my usb wifi.
Getting openwrt on it is no problem but no matter what version I use the Wan is not working.
It seems like there is no connection, no blinking lights at my switch.
I tried different cables, switches, routers and modems but no luck.
The older versions of Gl.inet firm also have this issue on my brume 2, it states no cable connected to wan port.
Wan works on gl.inet firmware 4.6.2 and up, with all devices and cables I tried before, and the light are flashing on my switch.
I am no expert with linux or openwrt so could realy use some help.
han@han-B85M-D2V-SI:~/build/openwrt-m-mt2500$ cat .config|grep 8811
CONFIG_PACKAGE_airoha-en8811h-firmware=y
CONFIG_PACKAGE_kmod-phy-airoha-en8811h=y
is there any other way to identify this MT2500A v2 version?
Not shure what you mean.
When I type this I get a not found reply.
When compiling the OpenWRT-24 firmware, you need to modify the DTS and add the en8811h driver
Ok.. Thanks
I tried but keep getting errors when compiling.
Will setup my desktop with linux and give that a go later this week.
My laptop take hours to end up with an error.
Well no luck compiling an image.
Been trying for almost a week now but cant get it done.
I did create 1 with wifi drivers installed last week but no nothing I do works.
That one I used to get connected and install the en8811h drivers but stil no lan.
Is there a way to compile online or could someone send it to me?
I can compile successfully, but you might have encountered a device tree syntax error. Please revise the dts file
Thank you very much!!!
This worked.. in your first reply it was just "d" and not "0xd" like you show me here or I misunderstood it...
Compiling was don in les the 10 minutes, before it took hours :astonished:
And now it works like a Charm.
Would you also happen to know how I can add an extra tap in luci?
I am hoping to link to Adguard home in the service tap .
So I can just click on te tap and adguardhome opens .
I have been reading all I could find about it but I cant seem to be able to find the Lua files on my device.
I have been using winSCP to brows through the folders but no luck so far.
Thanks again.
Hello I have a same problem with 2500
Could you kindly forward me - how to compile openwrt build?
Thank you
Hello Pyotr...
https://openwrt.org/docs/guide-developer/toolchain/use-buildsystem
This is the guide I followed.
My first tries took a long time.
You can either use a linux computer/laptop or run vm.
I use a linux mint laptop and Debian vm.
Personally I like to use a linux machine and modify the files in the gui.
Then make a minimal image for the device.
When I know all is working.. I make the image whit all the extras I like.
Thanks a lot!
Already compiling on my Ubuntu VPS...
But it takes too long time :frowning:
May be you can share ready binary?
I had the same issue.. it took me almost 20 hours the first times :grimacing: then ending with an error.
You need to edit the following file:
/target/linux/mediatek/dts/mt7981b-glinet-mt2500.dts in your compiling folder.
change it like icy showed in his second pic, ethernet-phy@5 to ethernet-phy@d and following the reg = <5>; to reg = <0xd>;
Locate the following files when compiling and ad them.
When done correctly only the first time takes a bit longer downloading all files needed.
I am not at home so can't get to my image for uploading
Thank you @Cindeade !
After few long )) attempts I compiled snapshot build with kernel 6.6.90 and wan works now!
But I have a problem with installing custom packages on it - for example Amnezia WG
Do you know how to compile not snapshot but stable release 24.10.1?
In the Openwrt how to compile, in step 2 you get a list of all available versions.
In step 3 type: git checkout v24.10.1
Then just continue following the instructions.
In menuconfig you can use forward slash ( / ) to locate packages you want to include.
so I just tried the OpenWrt 24.10.2 official version for the MT2500A and have the same issue - can not get the Wan interface to work. Does this mean that it is not yet supported yet
Hello! There are 2 versions exists of MT2500 - with Airoha chip and Maxline chip
In openwrt firmware selector choose snapshot version and start to type MT2500 and you can choose any of both versions…
I guess you should try Airoha
Good luck!
Ok Thankyou that explains something
However I’m probably not going to be up to quickly installing luci interface so hopefully these two versions will make it to the next release.
Do you know how to identify the different versions
I look - few days ago 24.10.3 released
I have installed it yesterday - it seems Wan problem solved
so 24.10.3 handles both hardware versions unlike the snapshots?
