First, apologies I this post is a duplicate, I thought I had clicked on “Create Topic” and I don’t know what append to the post.
I have my GL-MT300 connected to my modem and an Orbi connected to the GL-MT300 on its WAN port.
The connectivity is fine, the GL-MT300 assigns DHCP with a range of 10.0.0.100 to 10.0.0.160, the Orbi has a fixed IP of 10.0.0.2.
Each of them shows the correct IP on their respective admin page.
I was trying to set up the WireGuard Server by first enabling DDNS my ISP does provide me with a public IP.
Then, I generated a configuration file for my phone and scanned it into the WireGuard app on the phone.
The VPN connects immediately but I am not able to browse the internet while connected to that VPN.
Of course I disconnected the Wi-Fi on my phone and checked on cellular only.
Now, upon examining the settings of that config, I found out that the client (phone) was given an IP of 10.0.0.2, my Orbi is already using that IP, could that be the problem?
Below is the status of the client as it is connected to the WG server:
Oh… and I did allow access to LAN before generating the config.
Thanks in advance for any help.
You should look in the WireGuard config file for the [Interface] → Address line to see if it is assigning IP address 10.0.0.2 to the client device (phone). The VPN subnet should be different from the LAN subnet.
Most home networks use a 192.168.x.y Class C network on the LAN.
Below are the OpenVPN and WG Servers on my router
The OpenVPN has worked right away, WireGuard connects but no internet.
Both configs are using DDNS, I have enabled access to LAN and IP Masquerading was on by default.
My GL-MT3000 has an IP address of 10.0.0.1 and there is an Orbi access point with a static IP of 10.0.0.2.
The first client config generated by the router was assigning 10.0.0.2/32, I even created an additional one @10.0.0.3/32 to make sure it was not conflicting with my Orbi, still no Internet.
The VPN subnet has to be different from the LAN subnet. Your Wireguard VPN IP of 10.0.0.1 is on the same subnet as your router LAN IP of 10.0.0.2. Your OpenVPN VPN subnet of 10.8.0.0 is a different subnet.
Thank you, I actually found out this morning while I was looking at a video on the Brume GL-MV1000: the guy was setting up the WireGuard server for the first time and I saw that the server defaulted to 10.0.0.1/24 which was exactly what it did for me.
The problem was that when I first set up my router, I had changed its default address from 192.268.8.1 to 10.0.0.1
I just went ahead and changed the server config from 10.0.0.1 to 10.20.0.01, create new client configs and boom!
Everything works. I have access to my LAN and to the internet.
Thanks again.
