same error.
reinstalled from /tmp
Which version are you?
firnware 4.6.4
and my wireless speed is kinda slow (20mbps) versus before instaling the package.
I just upgraded to beta 4.7.0, and my wireless speed back to normal 160mps
The modem software package does not affect wifi
i see i see ![]()
Can you install the ipk normally now?
Still the same error?
using beta 4.7.0
the error now is
Cannot install package /tmp/gl-sdk4-modem...
sorry,my bad
try this
gl-sdk4-modem_git-2024.270.27687-b5d072a-1_aarch64_cortex-a53.zip (403.8 KB)
hi, sorry for late reply,
Installed successfully
root@GL-MT3000:~# opkg --force-reinstall install ./gl-sdk4-modem_git-2024.270.27687-b5d072a-1_aarch64_cortex-a53.ipk
Removing package gl-sdk4-modem from root...
rm: can't remove '/tmp/sms_manager_port': No such file or directory
Updating database.
Database update completed.
Installing gl-sdk4-modem (git-2024.270.27687-b5d072a-1) to root...
Configuring gl-sdk4-modem.
Updating database.
will try the modem
during connecting, it's FAILED succesfully, this is the log:
Thu Oct 17 08:24:30 2024 user.notice ModemManager: hotplug: error: modem not detected at sysfs path
Thu Oct 17 08:24:32 2024 daemon.info [15597]: <info> [device /sys/devices/platform/11200000.xhci/usb1/1-1] creating modem with plugin 'huawei' and '4' ports
Thu Oct 17 08:24:32 2024 daemon.warn [15597]: <warn> [plugin/huawei] could not grab port ttyUSB0: Cannot add port 'tty/ttyUSB0', unhandled port type
Thu Oct 17 08:24:32 2024 daemon.info [15597]: <info> [base-manager] modem for device '/sys/devices/platform/11200000.xhci/usb1/1-1' successfully created
Thu Oct 17 08:24:35 2024 user.notice ModemManager: hotplug: error: modem not detected at sysfs path
Thu Oct 17 08:24:36 2024 daemon.warn [15597]: <warn> [modem2/sim2] couldn't load operator name: SIM returned empty response 'FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF'
Thu Oct 17 08:24:36 2024 daemon.warn [15597]: <warn> [modem2/sim2] couldn't load list of emergency numbers: Failed to parse CRSM query result '+CRSM: 105,129,""'
Thu Oct 17 08:24:36 2024 daemon.info [15597]: <info> [modem2] state changed (unknown -> disabled)
Thu Oct 17 08:24:40 2024 user.notice ModemManager: hotplug: modem exported successfully at /sys/devices/platform/11200000.xhci/usb1/1-1
Thu Oct 17 08:24:40 2024 user.notice ModemManager: hotplug: setting interface 'Broadband' as available
Thu Oct 17 08:26:10 2024 daemon.notice netifd: Interface 'modem_1_1' is setting up now
Thu Oct 17 08:26:17 2024 daemon.notice netifd: modem_1_1 (31655): sh: 1: unknown operand
Thu Oct 17 08:26:19 2024 daemon.notice netifd: modem_1_1 (31655): Trying to set mode
Thu Oct 17 08:26:21 2024 daemon.notice netifd: modem_1_1 (31655): cat: can't open '/tmp/modem.1-1/signal': No such file or directory
Thu Oct 17 08:26:21 2024 daemon.notice pppd[31800]: pppd 2.4.8 started by root, uid 0
Thu Oct 17 08:26:22 2024 local2.info chat[31804]: abort on (BUSY)
Thu Oct 17 08:26:22 2024 local2.info chat[31804]: abort on (NO CARRIER)
Thu Oct 17 08:26:22 2024 local2.info chat[31804]: abort on (ERROR)
Thu Oct 17 08:26:22 2024 local2.info chat[31804]: report (CONNECT)
Thu Oct 17 08:26:22 2024 local2.info chat[31804]: timeout set to 10 seconds
Thu Oct 17 08:26:22 2024 local2.info chat[31804]: send (AT&F^M)
Thu Oct 17 08:26:22 2024 local2.info chat[31804]: expect (OK)
Thu Oct 17 08:26:22 2024 local2.info chat[31804]: ^M
Thu Oct 17 08:26:22 2024 local2.info chat[31804]: OK
Thu Oct 17 08:26:22 2024 local2.info chat[31804]: -- got it
Thu Oct 17 08:26:22 2024 local2.info chat[31804]: send (ATE1^M)
Thu Oct 17 08:26:23 2024 local2.info chat[31804]: expect (OK)
Thu Oct 17 08:26:23 2024 local2.info chat[31804]: ^M
Thu Oct 17 08:26:23 2024 local2.info chat[31804]: OK
Thu Oct 17 08:26:23 2024 local2.info chat[31804]: -- got it
Thu Oct 17 08:26:23 2024 local2.info chat[31804]: send (AT+CGDCONT=1,"IP","byu"^M)
Thu Oct 17 08:26:23 2024 local2.info chat[31804]: timeout set to 30 seconds
Thu Oct 17 08:26:23 2024 local2.info chat[31804]: AT+CGDCONT=1,"IP","byu"^M^M
Thu Oct 17 08:26:23 2024 local2.info chat[31804]: send (ATD*99***1#^M)
Thu Oct 17 08:26:23 2024 local2.info chat[31804]: expect (CONNECT)
Thu Oct 17 08:26:23 2024 local2.info chat[31804]: ATD*99***1#^M^M
Thu Oct 17 08:26:23 2024 local2.info chat[31804]: CONNECT
Thu Oct 17 08:26:23 2024 local2.info chat[31804]: send ( ^M)
Thu Oct 17 08:26:23 2024 daemon.info pppd[31800]: Serial connection established.
Thu Oct 17 08:26:23 2024 kern.info kernel: [581749.249629] 3g-modem_1_1: renamed from ppp0
Thu Oct 17 08:26:23 2024 daemon.info pppd[31800]: Renamed interface ppp0 to 3g-modem_1_1
Thu Oct 17 08:26:23 2024 daemon.info pppd[31800]: Using interface 3g-modem_1_1
Thu Oct 17 08:26:23 2024 daemon.notice pppd[31800]: Connect: 3g-modem_1_1 <--> /dev/ttyUSB0
Thu Oct 17 08:26:23 2024 user.warn : skip line without '=' Default
Thu Oct 17 08:26:23 2024 user.notice ModemManager: hotplug: add network interface ppp0: event processed
Thu Oct 17 08:26:23 2024 user.notice ModemManager: hotplug: event reported: action=add, name=ppp0, subsystem=net
Thu Oct 17 08:26:23 2024 user.notice ModemManager: hotplug: error: parent device sysfspath not found
Thu Oct 17 08:26:23 2024 daemon.warn [15597]: <warn> [ppp0] invalid sysfs path read for net/ppp0
Thu Oct 17 08:26:23 2024 daemon.warn [15597]: <warn> [base-manager] couldn't handle kernel event: device net/ppp0 not found
Thu Oct 17 08:26:23 2024 user.notice ModemManager: hotplug: move network interface 3g-modem_1_1: event processed
Thu Oct 17 08:26:23 2024 user.notice ModemManager: hotplug: event reported: action=move, name=3g-modem_1_1, subsystem=net
Thu Oct 17 08:26:23 2024 daemon.warn [15597]: <warn> [base-manager] couldn't handle kernel event: Invalid 'action' parameter given: 'move' (expected 'add' or 'remove')
Thu Oct 17 08:26:54 2024 daemon.warn pppd[31800]: LCP: timeout sending Config-Requests
Thu Oct 17 08:26:54 2024 daemon.notice pppd[31800]: Connection terminated.
Thu Oct 17 08:26:54 2024 user.notice ModemManager: hotplug: remove network interface 3g-modem_1_1: event processed
Thu Oct 17 08:26:54 2024 user.notice ModemManager: hotplug: event reported: action=remove, name=3g-modem_1_1, subsystem=net
Thu Oct 17 08:26:55 2024 daemon.notice pppd[31800]: Modem hangup
Thu Oct 17 08:26:55 2024 daemon.info pppd[31800]: Exit.
Thu Oct 17 08:26:55 2024 daemon.notice netifd: Interface 'modem_1_1' is now down
Thu Oct 17 08:26:55 2024 daemon.notice netifd: Interface 'modem_1_1' is setting up now
Thu Oct 17 08:27:02 2024 daemon.notice netifd: modem_1_1 (32389): sh: 1: unknown operand
and then in webUI become like this:
thanks so much for your support, I just give up using this dammed modem
Is it convenient for me to take a look at it remotely?
sure, how?
Technical Support via GoodCloud.tar (192 KB)
Please refer to this document
Then send me your mac address and password privately
okk, where can I reached you? email?
I get device bindings failure
Thu Oct 17 08:45:35 2024 daemon.info gl-cloud[19950]: (gl-cloud:967) lua-eco version: 3.6.0
Thu Oct 17 08:45:35 2024 daemon.info gl-cloud[19950]: (gl-cloud:806) mt3000/4.7.0/9483c44b3e73
Thu Oct 17 08:45:35 2024 daemon.info gl-cloud[19950]: (gl-cloud:393) Ubus services init done.
Thu Oct 17 08:45:35 2024 daemon.info gl-cloud[19950]: (gl-cloud:672) fetch server from: https://gslb-eu.goodcloud.xyz/getbucket
Thu Oct 17 08:45:36 2024 daemon.info gl-cloud[19950]: (gl-cloud:751) connect mqtt broker: 100.28.9.71 18883
Thu Oct 17 08:45:36 2024 daemon.info gl-cloud[19950]: (gl-cloud:810) conack: 0 connection accepted
Thu Oct 17 08:45:36 2024 daemon.err gl-cloud[19950]: (gl-cloud: 36) .../gl-sdk4-cloud/usr/local/lib/lua/5.3/cloud/astrowarp.lua:88: attempt to compare nil with number
Don't expose this information
Private send me
