I recently updated the firmware on my Beryl AX (GL-MT3000) router, which I’m using as a client, to version 4.4.5. After this, I’ve encountered connection issues to one of my Wireguard VPN servers. The error I’m receiving is: "Error: "inet6 prefix is expected rather than "".
To provide more context:
Server 1: Beryl AX GL-MT3000 with firmware version 4.2.3 (connects without issues).
Server 2: Beryl AX GL-MT3000 with firmware version 4.4.5 (connects without issues).
Server 3: Initially had firmware version 4.2.3 (faced connection issues). I upgraded it to 4.4.5, but the issue persists.
For all servers, I’ve already disabled IPv6 and enabled DDNS.
Has anyone else encountered this problem, and if so, is there a known solution? I’d appreciate any assistance or insights.
I have a newly purchased MT3000 and unable to connect to my existing wireguard server (many other clients work fine).
I was using 4.4.5 and received inet6 prefix expected error, and found this thread. Now updated to 4.4.6 release 2, and erased all settings. New error for wireguard client is:
Tue Oct 10 20:56:26 2023 daemon.notice netifd: wgclient (31083): * Zone ‘lan’
Tue Oct 10 20:56:26 2023 daemon.notice netifd: wgclient (31083): * Zone ‘wan’
Tue Oct 10 20:56:26 2023 daemon.notice netifd: wgclient (31083): * Zone ‘guest’
Tue Oct 10 20:56:26 2023 daemon.notice netifd: wgclient (31083): * Zone ‘wgclient’
Tue Oct 10 20:56:26 2023 daemon.notice netifd: wgclient (31083): * Set tcp_ecn to off
Tue Oct 10 20:56:26 2023 daemon.notice netifd: wgclient (31083): * Set tcp_syncookies to on
Tue Oct 10 20:56:26 2023 daemon.notice netifd: wgclient (31083): * Set tcp_window_scaling to on
Tue Oct 10 20:56:26 2023 daemon.notice netifd: wgclient (31083): * Running script ‘/etc/firewall.nat6’
Tue Oct 10 20:56:26 2023 daemon.notice netifd: wgclient (31083): * Running script ‘/etc/firewall.swap_wan_in_conn_mark.sh’
Tue Oct 10 20:56:26 2023 daemon.notice netifd: wgclient (31083): * Running script ‘/var/etc/gls2s.include’
Tue Oct 10 20:56:26 2023 daemon.notice netifd: wgclient (31083): ! Skipping due to path error: No such file or directory
Tue Oct 10 20:56:26 2023 daemon.notice netifd: wgclient (31083): * Running script ‘/usr/bin/gl_block.sh’
Tue Oct 10 20:56:26 2023 daemon.notice netifd: wgclient (31083): * Running script ‘/etc/firewall.vpn_server_policy.sh’
Tue Oct 10 20:56:26 2023 daemon.notice netifd: wgclient (31083): Failed to parse json data: unexpected character
Tue Oct 10 20:56:26 2023 daemon.notice netifd: wgclient (31083): uci: Entry not found
Tue Oct 10 20:56:26 2023 daemon.notice netifd: wgclient (31083): cat: can’t open ‘/tmp/run/wg_resolved_ip’: No such file or directory
Tue Oct 10 20:56:27 2023 daemon.notice netifd: Interface ‘wgclient’ is now down
Tue Oct 10 20:56:27 2023 daemon.notice netifd: Interface ‘wgclient’ is setting up now
Tue Oct 10 20:56:27 2023 user.notice mwan3[31174]: Execute ifdown event on interface wgclient (unknown)
Tue Oct 10 20:56:27 2023 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Can you help recommend next steps to fix wireguard client?
