GL-MT3000 ethernet connection drops & no reconnect
Did downgrade of Firmware now. Will not do the research and monkeywork to verify if this works.
Ordered a devolo WiFi 6 Repeater 3000, will replace this one tomorrow. Costs me less than a fraction of the time spent in this forum and troubleshooting so far.
Will dig this adapter out (GL-MT3000) maybe for an exotic travel where this might be helpful. Thread is closed.
Wow, just trying to help. Yes 5 minutes to downgrade the firmware, and if you had selected Keep Settings you would not have to gone through set-up again.
Anyway, sounds like you have bigger issues than just this, so have at it and best of luck.
Sorry for late reply. It is stupid long holiday here.
I checked your log and it has nothing there.
That is because you reboot the router and the log is gone. The next time when there is something wrong, get the log before reoboot the router.
I hope we can discuss your issue about starlink in your own thread.
