Upgraded my GL-MT3000 (operating in normal router mode) to firmware 4.6.2 and immediately started experiencing severe performance issues.
Even navigating the web console (from computer connected via 2.4GHz WiFi) became extremely slow.
While trying to navigate the web console/interface to try to configure the router, encountered many instances of the error:
Operation timed out. Please check the network environment or reboot the device.
Rebooted many times to no avail.
Checked the system log and found many occurrences of kernel error messages such as:
Sat Jul 27 14:32:44 2024 kern.err kernel: [ 3849.574883] 7981@C13L1,tx_free_v3_notify_handler() 3530: ContTxFailCntTotal = 1, ContTxFailCnt300ms = 1
Sat Jul 27 14:32:44 2024 kern.err kernel: [ 3849.584289] 7981@C13L1,tx_free_v3_notify_handler() 3533: token used by current wcid = 3, free_token_cnt = 2246
Sat Jul 27 14:32:50 2024 kern.err kernel: [ 3855.806932] 7981@C13L1,tx_free_v3_notify_handler() 3530: ContTxFailCntTotal = 1, ContTxFailCnt300ms = 1
Sat Jul 27 14:32:50 2024 kern.err kernel: [ 3855.816330] 7981@C13L1,tx_free_v3_notify_handler() 3533: token used by current wcid = 1, free_token_cnt = 2303
Sat Jul 27 14:32:54 2024 kern.err kernel: [ 3859.304225] 7981@C13L1,tx_free_v3_notify_handler() 3530: ContTxFailCntTotal = 1, ContTxFailCnt300ms = 1
Sat Jul 27 14:32:54 2024 kern.err kernel: [ 3859.313629] 7981@C13L1,tx_free_v3_notify_handler() 3533: token used by current wcid = 1, free_token_cnt = 2183
Sat Jul 27 14:32:54 2024 kern.err kernel: [ 3859.367055] 7981@C13L1,tx_free_v3_notify_handler() 3530: ContTxFailCntTotal = 1, ContTxFailCnt300ms = 1
Sat Jul 27 14:32:54 2024 kern.err kernel: [ 3859.376446] 7981@C13L1,tx_free_v3_notify_handler() 3533: token used by current wcid = 123, free_token_cnt = 2182
Sat Jul 27 14:33:02 2024 kern.err kernel: [ 3867.251867] 7981@C13L1,tx_free_v3_notify_handler() 3530: ContTxFailCntTotal = 1, ContTxFailCnt300ms = 1
Sat Jul 27 14:33:02 2024 kern.err kernel: [ 3867.261262] 7981@C13L1,tx_free_v3_notify_handler() 3533: token used by current wcid = 120, free_token_cnt = 2185
Sat Jul 27 14:33:15 2024 kern.err kernel: [ 3880.583761] 7981@C13L1,tx_free_v3_notify_handler() 3530: ContTxFailCntTotal = 1, ContTxFailCnt300ms = 1
Sat Jul 27 14:33:15 2024 kern.err kernel: [ 3880.593165] 7981@C13L1,tx_free_v3_notify_handler() 3533: token used by current wcid = 1, free_token_cnt = 2303
Sat Jul 27 14:33:23 2024 kern.err kernel: [ 3888.331407] 7981@C13L1,tx_free_v3_notify_handler() 3530: ContTxFailCntTotal = 1, ContTxFailCnt300ms = 1
Sat Jul 27 14:33:23 2024 kern.err kernel: [ 3888.340803] 7981@C13L1,tx_free_v3_notify_handler() 3533: token used by current wcid = 586, free_token_cnt = 1719
Running checks using Speedtest-dot-net would give a maximum download performance of 0.26 Mbps. One time was only 0.05 Mbps. Yet upload was typically over 100x as fast: usually around 25 Mbps.
Made many reboots and configuration changes - no success.
Downloaded the older 4.5.16 from GL.iNet download center. Couldn't upload the tar file from the normal GL-MT3000 web interface - kept giving "failed to upload" error message. Was however able to go to the "Advanced Settings" and upload and apply the tar file from there.
Even after downgrading to 4.5.16, download performance max'd out at 0.17 Mbps.
Then used the Reset Firmware option and download performance was restored: ~75 Mbps (from laptop using WiFi).
Repeated the entire process (re-upgrading to firmware 4.6.2) and problem re-occurs. Extremely slow download speed and kernel errors in system log.
Solution again:
- Apply the
4.5.16firmware - Choose the Reset Firmware option
- Re-configure personal settings
