Hello, can someone help me find the issue im facing with my GL-MT3000 ? All works good except watching from my ISP streaming service. Its like the router block the streaming service after couple channel swaps or if i watch one station for 1hour and then want to switch to another i get blocked. I have tried with other router and its working fine, so its not my isp blocking the router.. Thank you
Try to enable the IGMP Snooping.
What funtion do the router enable?
That was the option that caused this issue.. I did disable it and now the error is gone.. but the picture quality is very bad with this turned off..
- Is TV box a wired connection with MT3000 and ISP modem?
- Is there internet speed test function on TV box? Please test it to know how about the speed results
- Can TV box be connected directly to ISP modem?
After upgrading to beta firmware everything works good now (even picture quality is better). I'm connected on 5g wifi to tv box and with vpn and with disabled igmp spoofing (if i enable this it wont work, probably isp or box service have some filtering in place which prevent igmp to work as it should.. tested it with Asus RT-AC59U V2). Overall great little router.. exceeded my expectations ![]()
