Hi, is it possible to use a bluetooth adapter on USB port at GL-MT3000 to connect smartphone for tethering? If yes, which usb-bluetooth-adapter would work and which extra software packages have I to install?
I highly doubt it.
And it does not make much sense as well because bluetooth is pretty slow most of the time. Wi-Fi or USB tethering works fine.
Thx, thought bluetooth in actual version is fast enough
Tbh, I never tried it since a few years. So it might be fast enough - but getting the Bluetooth adapter running should be painful since the necessary modules might not be enabled.
