GL-MT3000 not upgrading firmware (stuck on 4.7.0)
Hi all,
My GL-MT3000 is on Firmware 4.7.0. I am trying to update the firmware. I’ve tried automatically doing it, and also downloading the firmware and doing it locally/manually.
The process runs, looks successful, then reboots the router, and when you log in, it’s still on 4.7.0, and the window popup telling you there is a new version 4.8.1, do you want to upgrade?
Not sure why it’s doing this. I’ve tried it numerous times. I really don’t want to do a full reset and try it.
Has anyone had this issue?
Is repeater enabled on the router?
Please try to disable WiFi 2.4G and repeater first before trying to upgrade. Re-enable them after the upgrade is successful.
Geez thank you very much! That did the trick!
