GL-MT3000 Obfuscated NordVPN Servers Not Connecting
Has anyone successfully got NordVPN to connect to a Obfuscated UDP server?
Everything goes fine with uploading the configuration file, setting credentials and selecting the server etc, but it never connects successfully.
I've no issue with a regular UDP/TCP or Wireguard connection not connecting.
I assume they are not supported because they don't use plain WireGuard.
Wireguard works fine. It's the UDP Obfuscated server connection that doesn't connect.
Hey CF, any luck figuring out how to connect to a nord obfuscated server via the GL inet router?
I am in the same position, quite frustrating. Same with double vpn.
Anyone successfully connected?
