I have upgraded my router to 4.4.6
The upgrade was successful, but when the router came back up the network ssid that was configured for 5Ghz network disappeared.
It is still enabled according to settings in UI, not set to hidden, but not available for devices to connect.
Export the system log.
Is the power plug the original one? All the client device can not see the wifi?
If that’s true, contact customer service please.
i have this problem also. router was working fine for a few weeks on 4.4.6, now all of sudden today the 5ghz SSID is not allowing my devices to find it. it ocassionally shows up but then disappears again. primary devices i have that require connection is mbp 16 (2019) and iphone 15 pro max.
My issue is with iPhone on ios 17 and macbook pro on mac os 14 & 13. My windows laptop sees 5Ghz just fine.
There appears to be a general incompatibility with the later iOS version and gl-inet router software.
I had a live debug session where gl-inet agent said they will reproduce locally, and let me know if there is a workaround/patch to fix the problem.
I’ll update this thread if they come up with a fix anytime soon and i don’t completely give up on this router…
