GL-MT3000 toggle button: guest wifi - remember config
Dear Community,
In my home configuration I use 2.4Ghz wifi only. No need 5Ghz.
Toggle button on my router is set to enable/disable guest wifi.
The problem is that when I enable wifi with the button, it activates both 2.4Ghz and 5Ghz guest networks.
Is there a way for the router to remember that only 2.4Ghz has been in use when it is disabling guest wifi, and then when enabling it back to activate only 2.4Ghz?
This looks like possible improvement for future version of the firmware.
Cheers
Jan
Thanks for your suggestions. This is indeed a more personalized application.
Such requirements will be collected and submitted to PM team for feasibility assessment.
Wonderful! Thank you!
