GL-MT3000 unable to install 4.7 firmware
I am unable to upgrade to 4.7.0. I have tried online as well as local upgrade.
Please advise.
it shows the progress going from 0 to 100% and also the check mark at the end but it continues not to be upgraded.
If anything fails and you can't install the firmware, try the Uboot method:
Please keep in mind that this will delete all settings.
Could you please kindly help to check these following points as well?
  1. the power supply of this router, with the adapter comes with the router or others?
  2. the Internet connection type, Ethernet or repeater?
  3. enable other features such as VPN, Adguardhome, etc. or not?
  4. use mobile phone or computer? And via wired cable or WiFi?
Thank you.
I have the same issue, did you solve it in the end?
I'd prefer not to use the uboot method in order to keep my settings
If you are just updating from 4.6 to 4.7 you can create a backup of your settings using luci before.
Thanks, I've done what you suggested and it worked :smile:
